Flywheel removal: what size bolt?
Old Jan 23, 2008 | 09:47 PM
MDeezy's Avatar
Trying to remove the flywheel on an 03 Maxima. What is the exact size of torx bolt used to remove the flywheel bolts? T50mm was a little too small and strips, T55mm is way too big. I would like to know the exact size so I can order the part, local auto stores dont have it.
thanks
Old Jan 24, 2008 | 07:20 AM
Derrick2k2SE's Avatar
I used T55 on my 02. It fit perfectly. I just double checked in my tool chest and thats it. I had to buy the tool because my set only went to T50.
Old Jan 24, 2008 | 10:44 AM
MDeezy's Avatar
Interesting. the T55 I had wouldnt fit, it was too big. and the T50 was too small.
Got mine from pepboys. I'l get a T55 and see if that fits again
Old Jan 25, 2008 | 06:41 AM
1trucavalier's Avatar
T55! make sure you torque it back to spec with a TW and use locktight on the threads. Someone I read didn't and there bolts backed out and you can guess the rest. If you are using a fidanza flywheel as a replacement PLEASE make sure its set to altima/maxima. I didn't and had to do it twice
Old Jan 25, 2008 | 12:01 PM
MDeezy's Avatar
going to pick a T55 up again today and try, it would make it a lot to finish the tear down if I could get this damn flywheel down.
I wonder why nissan switched to these type of bolts
Old Jan 26, 2008 | 10:14 AM
MDeezy's Avatar
Thank you all it was a T55. Got it off with ease with the impact.
Old Jan 26, 2008 | 04:38 PM
NisTech's Avatar
Most Japs use those 12 points these days on flywheels. Also on head bolts axle nuts (toyota) driveshafts, (ford). I guess cause it's harder to round off since it's got 12 points to grab on to.
Old Jan 27, 2008 | 04:00 PM
MDeezy's Avatar
true. Headbolts are 6pt, but rod bolts are 12pt.
either way its always good to have a set of 6pt and 12pts. never know when it will come in handy
Old May 17, 2008 | 09:32 AM
SurraTT's Avatar
HR Swap Pioneer
sorry to bring up a old thread.
but i cant find the torque specs for the flywheel bolts...
i got the FSM, idk whats up.
so anyone know where they are, and the proper seqence?
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
