scrapping in a turn
Old Feb 7, 2008 | 10:15 AM
tucker's Avatar
scrapping in a turn
Gents,
RE: 2001 SE AE. 95K on the clock
Whn making left hand turns I'm noticing a pulsating metalic scrapping noise from the wheel well. Any ideas?
Old Feb 7, 2008 | 01:19 PM
L.M.L.
brake pads?
Old Feb 7, 2008 | 03:17 PM
Jess's Avatar
SHIFT_In2D
Also check the dust shield. That is what happened when I replaced my brake rotors and pads. It was scraping the bottom of the shield.
Old Feb 7, 2008 | 09:58 PM
GodFather's Avatar
Made in Taiwan
Yes, check the dust shields first.
I also see this problem right after I dropped my car and steering was out of alignment. After the alignment, it is all good.
Hope I'm helping.
-Peter-
Old Feb 8, 2008 | 11:41 AM
macnolias's Avatar
Well I ran over a curb myself a couple of weeks ago... Being my lower control arm and strut assembly to cause your same problem. I fixed it though thank god
Also just while your car is parked in case it is plastic, just turn your wheel all the way in the direction to where you hear the noise and feel around your tire for places it could possibly be rubbing
Old Feb 9, 2008 | 03:01 PM
ajahearn's Avatar
This noise can also be caused by a bad bearing. I would start with the other (brake related) cases first.
Old Feb 9, 2008 | 05:41 PM
josurf02's Avatar
brakes!
Old Feb 9, 2008 | 06:36 PM
NisTech's Avatar
there is a stopper on your knuckle (behind the rotor) It looks like a bolt that has a plastic cap on it (sometimes that plastic falls off) When you turn all the way it touches the control arm. Get some bearing grease every oil change and put it on that. This noise will come when turning all the way to lock
If it does it when turning just a little (not full lock) check your brakes and also pull your dust shield from behind the rotor away with a small screwdriver prybar or hand so it wont touch the rotor
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
RealityCheck
Oct 2, 2015 06:34 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
