took out mass air flow sensor and check engine light went on!!!!!
Old Oct 28, 2001 | 09:55 AM
a33's Avatar
a33
i took out my mass air flow sensor so that my friend could try it on his max, he wasnt sure if his was broken, and we found out that his was broken after trying mine on his car.....
but when we put the mass air flow sensor back on my car, my car ran perfectly and the engine light came on
anyone know how to solve that?????
the mass air flow sensor is before the throttle body
Old Oct 28, 2001 | 10:01 AM
emax02's Avatar
Re: took out mass air flow sensor and check engine light went on!!!!!
Did you check your engine diagnostic code? It could be something like your air temp sensor, maybe you forget to plug it back in?
Old Oct 28, 2001 | 10:45 AM
UMD_MaxSE's Avatar
Got Bent?
Check to see that all sensors are plugged in and tight. If it doesn't go away, then leave the battery unplugged overnight to reset the ECU. That should take care of it.
Old Oct 28, 2001 | 10:51 AM
JUDE's Avatar
You only have to unplug the negative terminal, right?
Old Oct 28, 2001 | 11:42 AM
UMD_MaxSE's Avatar
Got Bent?
yup..
Old Nov 22, 2001 | 12:04 PM
PCGuRu2K's Avatar
Originally posted by UMD_MaxSE
yup..
I left it unplugged for about 3hrs.. Should I have left it unplugged longer? Cuz I still get that error..
Old Nov 22, 2001 | 12:15 PM
PCGuRu2K's Avatar
Originally posted by yo_its_ok
Maybe the connector on the MAF is not in all the way... you did say you just removed the MAF right ?
All I did was replace my JWT with the PR Cai...
Old Nov 22, 2001 | 12:45 PM
PCGuRu2K's Avatar
Ok you've lost me here ... you said you took out the MAF sensor and swapped it around in your friends car, and returned it back to your car....
Did you make sure you re-connected everything.
Do you rpms stop @ 2500 ? If they do, you haven't connected the MAF correctly or have possibly damamged the MAF from swapping it into your friends car, and may have a short along the lines of the ECU.
-Peace
yo_its_ok,
i wasn't the one that started the thread.. I'm just saying that I have the same prob..
Old Nov 22, 2001 | 12:53 PM
PCGuRu2K's Avatar
Ooops.... my bad ... LOL ... well go to Nissan and have it checked out
-Peace
I don't have my stock instake anymore... Do you think they'll still look at it?
Old Nov 22, 2001 | 01:19 PM
PCGuRu2K's Avatar
Where are you located ? They can always run diagnostic to find out the problem, you might be charged, but should the code be caused by the intake, you might have a problem, so you should return the intake to stock if possible.
I'm located in Queens. Right off of Queens Blvd & Grand Ave... Any recommendations which dealer I should go see??
Old Nov 22, 2001 | 01:28 PM
AznWontonboy's Avatar
stupid question.. is it ok to take out the intake for one race and wrap it with a towel and then put the airbox back on? No flames
Old Nov 22, 2001 | 01:29 PM
PCGuRu2K's Avatar
I know the service manager at Star Nissan, thats in Fresh Meadows, NY, Queens. He should be able to help out.
We will have a micro meet today on Franny Lew @ 7-11 just off the LIE. If you are interested we'll be there around 11pm.
Sounds good.. Which 7-11? right off of the lie, utopia exit?
Old Nov 22, 2001 | 07:49 PM
Altimat's Avatar
ActiveTuning Partner
An electrical problem of some sort in the other car may have toasted your MAF. This is why electrical parts are non-returnable. People buy them just to shotgun a repair and they can be damaged and are then unable to be retested when returned.
beboski
Aug 16, 2015 05:23 PM
doobadoo
Aug 15, 2015 06:43 PM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
