power seat not working?
Old Feb 16, 2008 | 12:18 PM
albundy's Avatar
I can get my seat to tilt back and forth but cant get it to go front/back and up/down..any way to narrow down problem? also every once in a great while it works but then shortly after it stops??thanks in advance
Old Feb 16, 2008 | 01:16 PM
Scottwax's Avatar
That's Mr. Detail to you
Sounds like a wiring problem to me. Make sure the connections are tight first.
Old Feb 16, 2008 | 01:33 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
motor going bad.. get a screwdriver and hit it, the motor is right under your legs
Old Feb 16, 2008 | 01:35 PM
KRRZ350's Avatar
There's a TSB out on this, don't know if it's old or not but I was at the dealer yesterday checking it out, the tsb needs to be referenced for your parts guy to get the # for just the motor.
Old Feb 17, 2008 | 05:08 PM
albundy's Avatar
I checked tsb online and it is from 04, called service dept. and said no current ones or recalls. I guess Il have to take a look at it when i get a chance
Old Feb 18, 2008 | 05:17 AM
2002 Maxima SE's Avatar
Mine stopped moving front/back. The problem turned out to be the rubber bumper that tells the motor the seat is all the way back (for the auto setting when the car is turned off). The rubber bumper over time got chewed up by the motor.
I bought a revised motor through this TSB:
http://maxima.theowensfamily.com/tsb/NTB02-001c.pdf
Changed it myself in a few hours.
Old Feb 18, 2008 | 01:35 PM
nismowolfe's Avatar
I have this same problem I just bang on it and it starts working again.
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
