White smoke and water in muffler
Old Feb 16, 2008 | 01:32 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Changed the brake master cylinder and now the car (is not my Max) has white smoke coming from the tailpipe and water too. What could be the problem, car was fine?
Old Feb 16, 2008 | 02:50 PM
Bluesbrekr's Avatar
Doctorate in Detailing
Moisture/water from a tailpipe is normal-nothing to worry about.
Old Feb 16, 2008 | 03:23 PM
Lontar1's Avatar
nope.. it is a lot of smoke.... white smoke
Old Feb 16, 2008 | 03:27 PM
jasonmax's Avatar
are you sure it's smoke not steam?
water in the muffler is normal
Old Feb 16, 2008 | 03:39 PM
ian02se's Avatar
Water is usually normal. Excesive white smoke can indicate burning coolant.
Old Feb 16, 2008 | 03:46 PM
syntax182's Avatar
Same thing happened to me before, had an ses light on though cause i need evap canister replaced. Happened when it was raining real hard, car was parked for 2 days, and when i tried to start, it would blow out a lot of white smoke, car would start for a few seconds then die. i just kept at it until it was gone and car started normal, replaced the canister a few days later and no problems since. Don't know if that gives you an idea of what it might be.
Old Feb 16, 2008 | 04:41 PM
nismowolfe's Avatar
Look to see if you have oil in your radiator. It could be a sign of a blown headgasket not to scare you but what your discribing is a symtom of blown head gasket. I dont think changing your master cylinder has anything to do with it.
Old Feb 16, 2008 | 05:58 PM
Lontar1's Avatar
That's what I have been reading.. Damn!!! i just took it for a spin and the smoke was way too much.. I think this car is fried... Damn It
Old Feb 16, 2008 | 07:15 PM
AceofSpds's Avatar
wat
blown headgasket/crack in block/warped head
Old Feb 16, 2008 | 08:34 PM
Lontar1's Avatar
car was running perfectly fine....... turned it off.. then on again.. and Boom... no overheating... perfect oil, no oil burning.. no nothing.. coolant at Max level.....!!!!
Old Feb 16, 2008 | 08:58 PM
Merlyn's Avatar
And... I'm out
You probably should have mentioned the fact it was over heating before anything else...
Old Feb 17, 2008 | 05:49 AM
Lontar1's Avatar
It wasn't.....over heating
Old Feb 17, 2008 | 06:34 AM
Matt93SE's Avatar
STFU n00b!
did you spray anythign into the vacuum hoses or intake while it was off?
do a compression check on the engine. if everything looks good, then drive it and see if the smoke goes away.
Old Feb 17, 2008 | 07:41 AM
Lontar1's Avatar
nothing sprayed into the intake........
Old Feb 17, 2008 | 08:04 AM
6SPD02SE's Avatar
Sounds like your headgasket is seeping coolant into the cylinders. If thats the case and you keep driving it, it will eventually get worse and you could destroy your engine. The coolant will start mixing with the oil.
Old Feb 17, 2008 | 08:10 AM
Merlyn's Avatar
And... I'm out
Anyway... if it is still smoking... smell the smoke.... if you want to throw up and it smells really sweet, it is anti freeze, if you don't want to throw up, back away and look at the smoke, if it is a tint of blue, then it is oil
Old Feb 17, 2008 | 08:20 AM
DOHCtorJT's Avatar
Check your hose routing, I bet something was incorrectly hooked up when you changed the master cylinder.
Old Feb 17, 2008 | 08:22 AM
maximalxl's Avatar
hey quick question since this forum is about exhaust..... in a dual SE stock muffler....wen the car is ideal only one tip spits out exhaust.....
Old Feb 17, 2008 | 08:40 AM
jasonmax's Avatar
someone had asked about this about 2 days ago, and I answered it.
It's normal.
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
BobTX10
Oct 7, 2015 08:43 AM
uttadms31
Sep 30, 2015 05:24 AM
