transmission flush
Old Mar 5, 2008 | 03:25 PM
dAAmax's Avatar
transmission flush
hey wasup members....i just finished doing a transmission flush today and i noticed that my car now seems more sluggish after i drove it around for 10 miles...but i think i did notice it got faster longer into the drive...is this common to happen after one of these flushes because the fluids need to run around a little bit? thanks
Old Mar 5, 2008 | 03:28 PM
maximalxl's Avatar
u did ur self?
give more details....how many miles on the whip...
Old Mar 5, 2008 | 03:40 PM
dAAmax's Avatar
nah my father did it which hes a mechanic for 30 years..lol he did everything perfect. i think it should just take a little time
Old Mar 5, 2008 | 04:34 PM
Darktide's Avatar
I would never recommend a flush of anything. Just replace fluids. Flushes always end up screwing something up. Just make sure that you've got enough fluid in there.
Old Mar 5, 2008 | 05:01 PM
nsnrider's Avatar
was the oil pan dropped? the magnets and the screen cleaned? If those were done then drive on it a bit, make sure the level is toped off and drain and refill with fresh oil.
By the way, how did he do the tranny flush?
Old Mar 5, 2008 | 05:12 PM
SoonerFan's Avatar
Cletus
people need to post more info if they want help
year of car
miles
how flush was done
fluid used
Old Mar 5, 2008 | 06:06 PM
dAAmax's Avatar
yeaahh... he cleaned magnets and everything.. put in new pan. 2000 nissan maxima se with 100k miles regular atf was used
Old Mar 5, 2008 | 06:07 PM
dAAmax's Avatar
i told him i wanted to put in "synthetic atf" and all the mechanis never heard of it and they thought it would be pointless and it wouldnt make much difference anyway unless u have a nascar ahaha
Old Mar 5, 2008 | 09:37 PM
Scottwax's Avatar
That's Mr. Detail to you
It is normal for new fluid to make the transmission feel different if the old ATF is dirty. The cleaners in the new ATF are circulation and knocking out crud in the valve body if the old ATF is bad enough.
Old Mar 6, 2008 | 01:04 PM
dAAmax's Avatar
yeah...today i beat on the whip a little...let the max run on some high gears. everything is good now, it just needed to flush around a little bit. thanks for your replies
Old Mar 7, 2008 | 03:25 PM
Manda_Max's Avatar
Good deal. I did the same thing and I felt like mine was sluggisg at first too. I just thought it was just my head. 100K perfect time to do it.
Old Mar 7, 2008 | 03:56 PM
BCoon's Avatar
Even a radiator? I'm planning on doing mine Monday as part of the 90,000 service Nissan wanted to charge me $500 for..
Old Mar 7, 2008 | 03:57 PM
SoonerFan's Avatar
Cletus
a radiator you should do so it doesnt get clogged and you have to replace it.
Old Mar 7, 2008 | 04:06 PM
BCoon's Avatar
Thank you sir.
user 11122324
42
Jul 18, 2022 03:35 PM
Pied
Sep 26, 2015 03:29 PM
