Loud bang at rear right when going over bumps
Old Mar 22, 2008 | 08:32 PM
jzwu's Avatar
There is this loud bang like bottoming out from the rear right on my 2001 GXE whenever going over speed bumps. Thought the rear struts were gone and replaced with Tokico Blues in rear but the noise is still there.
What could cause this? Bad bearing? The car's got 80k miles on it now. I have RSB installed years ago, otherwise everything else is stock in suspense.
Thanks!
Old Mar 22, 2008 | 09:02 PM
irish44j's Avatar
retired moderator
the RSB is probably out of adjustment and banging on the center assembly of the beam. Check the u-bolts for signs of contact. I'm assuming it's a cattman or addco RSB?
It isn't wheel bearings, that is for sure.
Old Mar 22, 2008 | 09:03 PM
jzwu's Avatar
Sure, it is a Cattman RSB I bought and installed myself.
I will take a look at the alignment.
Old Mar 22, 2008 | 09:04 PM
SoonerFan's Avatar
Cletus
yeah, probably the passenger side RSB ubolt...needs to be moved further out to the passenger side
Old Mar 22, 2008 | 09:13 PM
Bronzie2K's Avatar
I experienced the exact same problem for a while. Turned out I had a slow leak (nail).I thought the low pressure in the tire was the source but when I fixed the tire I continued to hear the same noise. I'll take into consideration what I-44j said.
Old Mar 23, 2008 | 07:05 AM
boondoxmax's Avatar
checked your exhaust. My exhaust pipe is now hitting the beam axle. Something has come loose back there but I haven't been able to what.....So every time I hit a dip in the road I get a loud banging noise
Old Mar 23, 2008 | 07:45 AM
nsnrider's Avatar
My exhust was also making a noise when going over bumps, its easy to check, just move the muffler side to side and up and down a bit and see if it hits anything.
Old Mar 23, 2008 | 09:28 AM
jzwu's Avatar
I checked the RSB and exhaust/muffler but saw nothing wrong. Perhaps I need to let a garage take a look at it. The loud bang happens mostly when I go over a bump/dip at a relative fast speed.
Old Mar 23, 2008 | 12:14 PM
makaveli_13's Avatar
check your scissor jack to make sure its tightened full.
Old Mar 23, 2008 | 01:17 PM
Tippy Toes's Avatar
Might just be a hanger. Just weld it back on. Easy fix if this is the case
Old Mar 24, 2008 | 12:57 AM
Craig_0530's Avatar
I choose not to comment.
Originally Posted by Tippy Toes
Might just be a hanger. Easy fix if this is the case
Old Mar 24, 2008 | 01:00 AM
SEmy2K2go's Avatar
Go BUCKS!!!
You think that one of the exhaust hangers broke? And it's an easy fix for anyone to do?
Old Mar 24, 2008 | 11:05 AM
spdfreak's Avatar
Pipe clamp.
Old Mar 24, 2008 | 12:20 PM
Kyle00's Avatar
WSH for teh cup
i had the same exhaust problem thats mentioned. I couldn't find a broken hanger... so i used ckicken wire that i looped around the exhaust, through a small hole on the ridge of the gas tank and twisted the ends together. Never have had a problem again
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
doctorpullit
Sep 10, 2015 06:33 PM
ef9
Sep 5, 2015 11:18 PM
