Shift Knob Removal
Old Mar 23, 2008 | 09:43 PM
mkim12180's Avatar
Shift **** Removal
Can anyone tell me the easiest/ best way to remove the oem shift ****, I'm considering purchasing the nismo titanium one.
Old Mar 24, 2008 | 03:49 AM
Puppetmaster's Avatar
What year is your car? What tranny? IIRC, the 4AT shift ***** are pretty tough, but nothing more than some elbow grease will get them out. Some people wrap a towel or rag around it and use some pliers or channel grips. Not sure about the 5MTs, but the 6MTs come off really easily.
Old Mar 24, 2008 | 08:06 AM
Froggmann's Avatar
If it's the 5.5 gen AT it just spins off. Most MT ones will just spin off too.
Old Mar 24, 2008 | 08:32 AM
nk2k2's Avatar
can you use the nismo titanium shift **** on a 4AT application?
Old Mar 24, 2008 | 09:31 AM
mkim12180's Avatar
I have an 01 5spd.
Old Mar 24, 2008 | 09:32 AM
mkim12180's Avatar
I tried to spin it off and it's not budging.
Old Mar 24, 2008 | 06:14 PM
NisTech's Avatar
grab a shop cloth or towel, wrap it around it and use big channel lock pliers to twist it off if it is seized. Most likely this removal will chew old one apart. if it rips rip it of completely and underneath the rubber there is the nut that threads onto the lever. then it's easier to come off.
Old Mar 25, 2008 | 08:55 PM
mkim12180's Avatar
This thing ain't budging.....
Old Mar 26, 2008 | 07:40 PM
nsnrider's Avatar
try spraying some penetrating lubricant like wd-40...twist harder.
Old Mar 27, 2008 | 10:55 AM
pikers's Avatar
lol what, do you try to take it off then run back inside to post?
Old Mar 27, 2008 | 04:39 PM
NisTech's Avatar
than brake the rubber and the nut underneath will come with a wrench or vise grips...
if still tight you heat it up a little.
Old Mar 27, 2008 | 04:44 PM
irish44j's Avatar
retired moderator
comeon girly man...use some elbow grease. It twists off.
Old Mar 27, 2008 | 06:25 PM
Deckdout2's Avatar
Play with my balls
- Go to the stealership
- Drive to one of the bays right before they close
- Ask guy to remove **** for you for 20 bucks
- Slip him money when done
- Take skirt off
- YOU screw new **** on
- Drive home
- ???Profit???
Old Mar 27, 2008 | 11:27 PM
p2kmax's Avatar
cut it off..lol i use a razor blade on mine and cut the outter boot then it sliped right off with a lil wd-40
Old Mar 28, 2008 | 06:09 AM
phatboislim's Avatar
if u dont plan on using that old shift **** again..just take the channel locks straight to it, lock it on and lefty lucy until it breaks loose and unscrew it. the oem shift **** is glued on, so i had to do the same when i replaced my oem one with the A.E. shift **** i have
Old Mar 29, 2008 | 10:10 PM
Yayomax's Avatar
still brewin'
Taking mine's off reminded me of how I used to get sore palms after trying to remove my too tight oil filter. Grip and twist till you pass out or use the right wrench.
Old Mar 29, 2008 | 11:50 PM
AnDyMaN's Avatar
yeah, you will have to use some kind of channel locks or something. It took quite a bit of effort, but it'll come off. oh, and your old shift **** will still be usable, it'll just be scratched up a lot.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
RealityCheck
Oct 2, 2015 06:34 PM
atriuum
Sep 28, 2015 01:19 PM
