My interesting experience with different grades gas
Old Mar 24, 2008 | 01:23 PM
jzwu's Avatar
Well, here is my experience with different grades of gas. It is a 2001 GXE, manual shift with about 80K miles, everything stock in engine/intake/exhaust.
With 87 octane gas, engine makes constant tatatatata noise at idle (ECU retarding timging?), very audible 'cuz my 12 yr old daughter can hear it loud and clear and asks me what's wrong with the car. LOL
With 89 octane gas, no engine noise but car feels sluggish on acceleration.
With 91 octane gas, car (throttle) feels very light and transmission shifts like butter, very strange though. Can gas can affect shifting?
So I would say gas DOES make a big difference based on my experience!
Old Mar 24, 2008 | 08:41 PM
Mattlikespeoples's Avatar
well, the engine is designed to run optimally with the high grade fuel. The lower octane stuff doesn't burn as efficiently under the high compression of this engine. Not sure why it would shift better but maybe the smoother engine operation makes it feel like it does
Old Mar 24, 2008 | 09:24 PM
jasonmax's Avatar
low grade gas on high compressure engine will cause engine knock, which is because the mixed air burns before the spark plugs producing sparks due to high heat form high compression.
Old Mar 24, 2008 | 09:32 PM
SoonerFan's Avatar
Cletus
glad that you learned from experience what we have been trying to convince some people of for years on here.
if it didnt matter, nissan wouldnt say to use premium
Old Mar 24, 2008 | 11:40 PM
95 Maxnout's Avatar
Premium ALWAYS............
Old Mar 25, 2008 | 02:15 AM
VQHP's Avatar
Sunglasses required..
"AGREE" some people just don't get it. They think all fuel is the same, but it's not. I used to own a 1991 maxima, went ahead and put 87 octane. At idle made a knocking noise. Switch over to 91 octane, smooth sailing after that. My choice, Shell,76, Mobil,Chevron.........that's it. Premium does a body good!
Old Mar 25, 2008 | 04:21 AM
Merlyn's Avatar
And... I'm out
Accidentally the first tank I put in my Maxima (2 years ago) was 87.. I still remember the day I filled her with 93... it makes a world of difference
Old Mar 25, 2008 | 07:51 AM
Scottwax's Avatar
That's Mr. Detail to you
Top Tier rated premium is all I use. 93 octane around here too.
Old Mar 25, 2008 | 08:09 AM
GETukrainian's Avatar
Shell is probably the best expirience I've head. I've had a couple bad expiriences with Cumby's, and Mobil is just too expensive.
Old Mar 25, 2008 | 08:36 AM
Froggmann's Avatar
I too played around with this when I first got my max (02 SE) on 87 I got sluggish performance but slightly higher mileage, possibily due to having to drive more conservitively. 89 was an improvement but not enough. 91 (the highest we can get in in comufornia) gives slightly lower mileage but allows the motor to work as it should.
As a side note on low octane fuel, when you use low octane fuel your ECU will retard the timing of your engine therefore opening up your exhaust valves sooner which in turn will cause you to have higher exhaust gas temps. In the short term it's not a problem but in the long term the higher temps can cause your exhaust componets to wear out quicker.
shilov
Feb 19, 2024 09:40 PM
Mar 12, 2020 12:06 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
97_GXE
20
Sep 17, 2015 08:12 PM
dcam0326
Sep 7, 2015 07:26 AM
