fstb adjusting
Old Oct 31, 2001 | 07:42 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
fstb adjusting
I tried search, but didnt see anything about if it is necessary to adjust the fstb after install. Its only been on a few months, and I know it was installed correctly and torqued correctly. It seems as there is some play from front to back. Its not a grea deal of play, but enough to make me think it might not be doing everything it can. All of the bolts are still tight, just curious if anyone else has had to re-adjust it after any amount of time.
Old Oct 31, 2001 | 08:04 AM
bcannon's Avatar
Re: fstb adjusting
I have the stillen and I just made sure it was centered...
Old Oct 31, 2001 | 08:41 AM
jnovember's Avatar
Courtesy FSTB
No play at all in any direction. No "twist play" as reported in other posts.
If you torque the bolts on the shocks to 35lbs and tighen everything else real tight (the crome "adjuster nuts" on bar itself and the "end plate bolts" which connect the bar to the end plate) you shouldn't have any problems, play, etc.
Just follow the directions at http://www.courtesyparts.com/html/inst_a33_stb.html
Good luck!
Old Oct 31, 2001 | 08:47 AM
theMax's Avatar
reinstall
if its loose, just loosten all the nuts on the bar, on a level surfase and retorque. The bar should be tight and not move to do its job.
Old Oct 31, 2001 | 08:51 AM
sloppymax's Avatar
thanks for the help. im pretty sure i did it right the first time, but ive got a little bit of time so im going to take it off just to make sure. i wanted to spray paint the brackets black anyways.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
