Drivers Seat not working
Old Apr 9, 2008 | 01:57 PM
c-stone's Avatar
Last year my driver's seat stopped moving forward, and of course I got quoted by the dealer for like a grand to fix. I'm wondering if anyone else has run into issues with the seats, and if it was just a quick wiring fix or something else. Oh ya and now the heating element is out as well in the seat portion.
Old Apr 9, 2008 | 02:03 PM
sergey85's Avatar
youu try a junk yard for the seats or car-parts
Old Apr 9, 2008 | 03:10 PM
jadedmatt's Avatar
idk about the heat, but hit the motor (which is in the front of the seat on the underside) with something, ie hammer. it will work again. mine "went out" when i got my car in sept of 06, hit it once and it has been working since.
Old Apr 9, 2008 | 03:53 PM
HogMaxFan's Avatar
There is a "TSB" on the power seat issue, it calls for replacing the seat slide motor kit, depending on your year, check the "TSB" thread on here.
Old Apr 10, 2008 | 07:53 AM
jdm01se's Avatar
I don't understand why you people go straight to the dealership in matters like these. It breaks my heart.
Anyway, the seat motor is located underneath your left thigh. If it's insanely hot it means that it's about to go. I had the same problem so I just took a hammer to it and it started working again.
G'luck.
Old Apr 10, 2008 | 09:20 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
just hit it with a screwdriver it will come back to life, of course for a few days and will die again but.. how often do you move your seat?
Old Apr 10, 2008 | 09:54 AM
jasonmax's Avatar
which one will kill the motors? using them or not using them?
Old Apr 11, 2008 | 11:56 AM
Lontar1's Avatar
If they are bad they will stop working no matter what you do.. I love sarcasm.... but more power to you..
Old Apr 11, 2008 | 12:11 PM
clayman88's Avatar
Yep...my drivers seat motor went out too. Luckily, I had an extended warranty on my I30 so it was covered.
Old Apr 11, 2008 | 12:53 PM
hi-tek22's Avatar
yea i took a hammer to my motor on my drivers side seat, it stopped going UP/DOWN at the front of the seat...Its been working ever since, If it stops working again, ill HIT THE JUNKYARDS, its not worth it at the dealer....plus my car didn't have heated seats, so if i PAID A GRAND per seat....HEATED SEATS ARE A MUST
Old Apr 12, 2008 | 08:45 PM
spdfreak's Avatar
I don't mean to post hijack, but since you guys have had seat motor issues you may have the answer to my minor problem.
The rear half of the seat won't raise or lower. I have looked at the FSM and as I see it there is one motor for sliding forward/reverse and another motor to raise/lower the seat. The front of the seat will raise/lower but the rear won't budge up or down.
Does this sound like a this a switch issue or a motor?
Old Apr 12, 2008 | 09:37 PM
unrealii's Avatar
I had the issue with a switch causing the front of the seat not to move up and down. It would move if I had the rear going up or down as well. It magically fixed itself when I performed the tsb to fix the drivers side lateral seat movement while making turns.
fyi, these seats are very sharp. Ended up slicing my finger, stabbing my toe and putting two scratches on the driver's side passenger door just trying to fix my seat. So, be careful.
Old Apr 12, 2008 | 11:01 PM
Drockb418's Avatar
check anything in the rails of the seat
rtirbany
Sep 8, 2015 11:46 AM
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
shaunkey1
Aug 18, 2015 10:09 PM
kenc15
Aug 5, 2015 08:29 AM
