Which would you buy and why........
Old Apr 30, 2008 | 11:54 AM
SterlingMist00's Avatar
I need to replace my front rotors, pads, for the 3rd time after 130K miles... and I am getting pretty sick of these warped rotors. So......after doing some research I have selected about 3 options (and some variations that are available thru Blehmco) and would like people to pipe in with their opinions on which one to buy:
Would you buy this set: http://www.racingbrake.com/MAXIMA_FR...2047-111-0.htm
or this set with 300zxrotors: http://www.blehmco.com/300ZX_brakes.htm
or this set with or without the rotors: http://www.blehmco.com/relocation_kit.htm
Old Apr 30, 2008 | 12:11 PM
MintVQ35's Avatar
Don't know much about the first set other than what the website says and it only lists up to 1999? Otherwise the kit looks decent.
300zx kit looks nice but pricey IMO for stock parts.
Last kit with relocation brackets and 04+ rotors looks to be the best deal to me.
The last 3 times you replaced the rotors, did you go with the OEM rotors each time?
Old Apr 30, 2008 | 01:22 PM
amomaxima's Avatar
the last kit wont be a noticable difference IIRC
the 2004 kit will just reduce heat
but no drastic breaking change
Old Apr 30, 2008 | 05:52 PM
SoonerFan's Avatar
Cletus
new OEM rotors
Hawk HPS pads
or
Old Apr 30, 2008 | 06:17 PM
illlojik's Avatar
I C U
Originally Posted by SoonerFan
new OEM rotors
Hawk HPS pads
or
tell him the price...
Old Apr 30, 2008 | 06:19 PM
SoonerFan's Avatar
Cletus
you get what you pay for...
and for the OP, OEM rotors dont cause the "warping" problem...its the OEM pads
Old Apr 30, 2008 | 06:31 PM
SuperStasiu's Avatar
new OEM rotors
Hawk HPS pads
or
Oem rotors = waste of money
bbk unless your doing autocross = pointless
Get some rotors from autozone and hawk hps pads it will work fine enough for daily driving
Old Apr 30, 2008 | 06:54 PM
SoonerFan's Avatar
Cletus
rotors from autozone will be OEM replacement...again, there is nothing wrong with the OEM rotors...its the OEM pads
and i completely disagree that a bbk is only good for auto-x
Old Apr 30, 2008 | 07:09 PM
maximalxl's Avatar
how bout Brembo Blanks + hawk pads.?
Old Apr 30, 2008 | 07:14 PM
MetaOrbit's Avatar
Got Projectors?
I'd just do 6th gen calipers and 6th gen rotors. Completely bolt on, no relocation brackets required.
I did it a long time ago and I haven't warped a rotor since. Of course, I switched to ceramic pads so that might have something to do with it, but the upgrade was cheap and I have been more than satisfied.
Old Apr 30, 2008 | 07:38 PM
SoonerFan's Avatar
Cletus
same as OEM replacement for more money
Old Apr 30, 2008 | 08:12 PM
Jamesrc's Avatar
I second the 6th gen set up for the money you can't go wrong. Although I belive your factory wheels will not clear. 5th gen no 5.5gen yes. Correct me if I'm wrong.
Old Apr 30, 2008 | 09:10 PM
i thought you ment oem from dealer lol
the bbk for spirited driving is over kill just cause of the price but if he can afford it then do it i was thinking price wise most people on here wouldn't wanna shell out 1000+ for it unless they do a 300ZX kit which you can do for around 600-800 maybe less
Old Apr 30, 2008 | 09:15 PM
MetaOrbit's Avatar
Got Projectors?
You're correct, but his sig said he had 18" BBS wheels so I figured clearance wouldn't be an issue in his case.
Old Apr 30, 2008 | 09:17 PM
SoonerFan's Avatar
Cletus
hell no...oem replacement. when i did my fronts, the dealership wanted around $200 each...got the exact same thing from advance auto for around $100 each.
think of a bbk as a safety thing
Old Apr 30, 2008 | 09:59 PM
miragetkg's Avatar
Just another suggestion. I just swapped out all four rotors & pads from irotors.com. Check them out.
Old May 1, 2008 | 10:01 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
powerslot and HPS... been using them for over 6 years... great combo
Old May 1, 2008 | 10:12 AM
phatboislim's Avatar
so i can bolt on 6th rotors and calipers on my 5th gen? absolutely no mods?
Old May 1, 2008 | 11:32 AM
MetaOrbit's Avatar
Got Projectors?
Always has been the case, provided the calipers will fit behind your wheels.
00-01 SE 17s won't work, 02-03 SE 17s will. And I'd venture a guess that anyone with 18" or larger wheels would have no trouble at all fitting the calipers.
Old May 1, 2008 | 11:42 AM
ok...thats wierd cuz the 5th gen adn 5.5 look the same as far as the 17s go. but thanks for the info. when i upgrade wheels ill upgrade calipers and rotors.
Old May 1, 2008 | 06:01 PM
The last 3 times were either BREMBO cross-drilled or Powerslot rotors and either metalmatrixpads or the current Akebono ceramic pads
Old May 1, 2008 | 06:28 PM
Correct....I have BBS RGR 18x8 rims so clearance will not be an issue.
Also, I am not concerned about better bracking per se but more importantly a better heat sink therefore less heat and less chance of warping.
Metaorbit thanks for the 6th gen rotors idea with the 6th gen calipers; i didn't know that this would work with no relocation brackets
I am currently leaning towards this setup. How much did it cost you?
Old May 1, 2008 | 07:16 PM
Jamesrc's Avatar
I bought my calipers from my work (nissan dealer) for $55 dollars each & hardware was $45. Bought them for a 05 because they were new not remans. Because they were new there was no core charge. Rotors & pads were free (warrenty take offs). Yea I'm cheap, I am not sure what year you would have to shop for new ones currently.
SE-R altimas will work as well I belive but there more money cause they say SE-R
Old May 1, 2008 | 09:32 PM
MetaOrbit's Avatar
Got Projectors?
Like Jamesrc said, the calipers are pretty cheap. I don't have any hookups but I think I got the '05 calipers, new, for like $64 a piece maybe. Not sure, it was a long time ago. I then bought a pair of rotors for like $120 shipped and bought the pads and pad hardware kit locally, can't remember how much I spent on those.
Old May 2, 2008 | 06:14 AM
bladerunr's Avatar
RTP Xdrill/slotted rotors from Automax95 in GD section and Advance Auto cheapo pads - great combo for over a year now.
Old May 2, 2008 | 02:38 PM
maxspeedse02's Avatar
Thinks he is fast
I've had this setup for close to three years with no issues. I like the bbk idea however it doesn't really seem like a smart idea to spend 1/3 of the car's value just on brakes. My $.02
Old May 2, 2008 | 03:06 PM
SoonerFan's Avatar
Cletus
so you wasted all that money on expensive fancy rotors...and bought crap pads
you clearly do not understand brakes AT ALL
Old May 4, 2008 | 06:45 AM
Do the 6th gen calipers have a bigger "piston" to squeese the rotors or is it the same size as the 5the gen caliper?
Old May 4, 2008 | 06:47 AM
MetaOrbit's Avatar
Got Projectors?
Much bigger piston. Bigger caliper overall.
Old May 4, 2008 | 08:54 AM
That is what I was hoping to hear... It is settled then. I will source the 6th gen calipers and rotors ( and decide on which pads i will choose) and install them myself.
I will probably give DaveB a call and see what his prices are...
p.s.- i know since i am getting bigger calipers and rotors that i am increasing my unsprung weight up front; i guess it is a tradeoff I will have to live with to get rid of this brake warping issue...
Old May 4, 2008 | 08:59 AM
SoonerFan's Avatar
Cletus
Old May 4, 2008 | 10:32 AM
boondoxmax's Avatar
agree. I haven't had any problems with OEM rotors and aftermarket pads. I use Bendix pads and all is good.......No need to speed tons of money
Old May 5, 2008 | 03:27 PM
I have used various rotor and pad combinations in addition to using different pads with the OEM rotors and everything thus far has warped.....I am more than likely going the 6th gen route to resolve the issue
Old May 5, 2008 | 03:33 PM
Is there any change in pedal feel, pedal travel, in how quickly/slowly the brakes start to grab that you may have noticed since this now involves a bigger caliper with a bigger piston but the same size master cylinder...
Old May 5, 2008 | 05:02 PM
MetaOrbit's Avatar
Got Projectors?
Pedal feel is different...it's hard to describe. There's more pedal travel now than there was stock, and the brakes start to grab later (more travel required) than stock. I remember with the stock brakes it seemed like the absolute first ounce of pressure on the pedal the brakes were biting hard. Doesn't happen that way any more. If anything it feels more linear to me.
Old May 5, 2008 | 06:08 PM
nsnrider's Avatar
does your car have abs? I noticed that cars without abs tend to grab fster than cars with abs.
how much farther does the brake travel with the 6th gen setup compared to the stock setup?
also, after your 6 gen brake conversion, do you feel it was worth it for a daily driver?
I never had a problem with my stock brakes, but worth thinking about if it makes a significan difference.
Old May 5, 2008 | 06:42 PM
MetaOrbit's Avatar
Got Projectors?
Yes, my I35 has ABS
Couldn't tell you. I just know it's farther.
No regrets, and I've had these brakes installed since Oct. 2005 (wow! just checked) and haven't had the rotors turned or the pads changed since.
I drive the hell out of my cars (lots of miles in a short span) so I touch these brakes pretty much everyday. Aside from the added weight (it's noticeable), I've been very pleased.
Old May 6, 2008 | 08:39 AM
Jeff92se's Avatar
I'm needing a caw
300zx/Q45 calipers + 13" Cobra rotors + brackets = ftw
Old May 7, 2008 | 06:17 AM
Hmmmmm.........so since this is increased unsprung weight and this is also rotational mass how much noticeable is it....and in what ways- slower to accelerate, slower to change direction....?
Old May 7, 2008 | 07:28 AM
MetaOrbit's Avatar
Got Projectors?
Pretty much feels like it does when you put heavier wheels on your car.
