Car struggles to 3500 RPM then takes off: is this a VIAS or MAF issue?
Old May 15, 2008 | 06:25 PM
mdeal's Avatar
My car is having trouble reaching 3500 RPMs, then once it finds that mark, accelerates as it should. This happens in every gear.
My first impression was it seemed the transmission was slipping. This is an automatic. The RPMs seem to climb while accelerating but the speed does not match..until I hit 3500 RPM then the car takes off.
I found a similar thread where this guy's car died AFTER 3500 but mine struggles BEFORE 3500.
The MAF has never been replaced (I am back to my stock airbox). No error codes being thrown. I have not checked the VIAS plunger thingy.
Thoughts?
Old May 15, 2008 | 06:27 PM
AEMAXIMA01's Avatar
How far below 3500 does it start to bog down? I replaced my MAF back in march and it fixed my problem. It would bog down between 3000 and 3500. Now there is no bog at all.
Old May 15, 2008 | 06:45 PM
mdeal's Avatar
If I leave a traffic light under normal acceleration or a little more, it pretty much feels like the transmission is slipping but the RPMs are going up. Once it hits 3500 it takes off.
If you very lightly accelerate the car seems to work its way up there fine.
When in drive, car downshifts fine. I can shift into D2 or D1 just fine, too.
Old May 15, 2008 | 08:25 PM
AEMAXIMA01's Avatar
Well, I can't really relate to you. I have a 5spd.
Old May 15, 2008 | 09:21 PM
Scottwax's Avatar
That's Mr. Detail to you
Pick up some CRC MAF Sensor Cleaner. I had a slight bog around 2500 rpm after I got a K&N panel filter. Sprayed the MAF sensor and screen down with the cleaner and no more bog.
Old May 15, 2008 | 09:29 PM
choiiiiiiiiiii's Avatar
i have the same problem...i have a code however. random cylinder misfire..p0300 i believe..
gonna replace the coils sometime and see if gets any better....
Old May 15, 2008 | 09:46 PM
Jess's Avatar
SHIFT_In2D
Hey it most likely is the MAF especially on the 5th gens I have the CRC maf cleaner Scott is talking about.
Since you're local stop by the meet on Sunday and we can try it out to see if it helps you any.
Info on the meet is in the South East Regional forums under "1st Annual AMD bbq".
Haven't had the chance to use it.
For me it turned out that I needed new ATF fluid.
Old May 16, 2008 | 01:45 PM
mdeal's Avatar
I picked up some of the CRC stuff and will give it a shot. No show for me. I've returned the car to stock and am putting it up for sale.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
