Anybody have pictures of the O2 sensor wiring at front of 3.5 engine?
Old May 26, 2008 | 10:48 AM
made in china's Avatar
I recently had to install the pre-cats and all 4 O2 sensors on my 3.5 to pass my emissions test. However, I can't figure out how the front 3 O2 sensors are routed. The cables have zip-tie clips that snap into holes somewhere on brackets (I am guessing) either on the engine or some other parts. I must be missing these brackets because I can't figure out where to route the O2 wires. For now, I have them tied up away from hot or moving parts, but I'd like to get them routed correctly. I can't find clear pics in the FSM, so I am hoping someone has engine pics that happen to clearly show the front 3 O2 sensor cables being routed. So, if you have pics like this, could you please post them?
I have the harness correctly routed under the engine cover, and the rear o2 sensor is correctly routed, I just need pics of the 3 in the front of the car.
Here's what mine looks like:
Old May 26, 2008 | 01:43 PM
SoonerFan's Avatar
Cletus
the 3 right ones go to the right
you didnt pay attention when you removed them
Old May 26, 2008 | 04:58 PM
I put this drivetrain into my A32, so I didn't pay much attention at the time I was parting out the donor car.
Old May 26, 2008 | 05:03 PM
SoonerFan's Avatar
Cletus
this is an example of when providing more information will help us answer the problem
it shouldnt matter...just run them wherever you want
Old May 26, 2008 | 08:13 PM
I just want to know where they run on a stock 5.5 Gen. Yes I have them run a certain way but I'd just like to see if anyone has pics of the stock setup so I can do it exactly as Nissan would.
Old May 26, 2008 | 08:19 PM
SoonerFan's Avatar
Cletus
you will see holes for those plastic tabs to go....as a said, the right three go to the right
Old May 28, 2008 | 09:00 PM
DJ2Max's Avatar
whats wrong with how you have it now. They were a ***** to take out with the default route.
Old May 29, 2008 | 06:18 AM
NmexMAX's Avatar
dot dot dot ...
There is also one (primary) near the PCV valve, which I don't have a picture of.
This may or may not help:
http://forums.maxima.org/showthread.php?t=350787
Old Jun 1, 2008 | 11:43 AM
Thanks for the links, very helpful info. I like your headers, what kind are they?
I noticed an obvious decrease in power when removing my VQ30DE manifolds/warpspeed Y pipe (duh I know) and switching over to the stock VQ35DE stuff. However, I like how quiet the car is now (noisy Y pipe). But I am definitely considering going the full header/y-pipe route now that I experienced the difference for myself. Are people passing emissions with the sims?
Old Jun 2, 2008 | 06:22 AM
NmexMAX's Avatar
dot dot dot ...
I don't think you even need sims actually. Leave the main cat in place, and you should be good if they use a tailsniffer. Just add a bung in the new headers. Those are Cattman gen I headers.
This might help re: passing e-tests.
http://forums.maxima.org/showthread.php?t=562608
Old Jun 2, 2008 | 08:13 AM
eng92's Avatar
.... But I am definitely considering going the full header/y-pipe route now that I experienced the difference for myself. Are people passing emissions with the sims?
I have Cattman gen II headers on my VQ35. I sim one of the downstream sensors and the other one is wired to the stock sensor in the aftermarket A32 b-pipe. No codes and I pass emissions with a tailpipe sniffer.
Old Jun 2, 2008 | 03:13 PM
My emmissions place popped me on the heater codes for the missing downstreams. That's the only reason I swapped in the stock stuff. They wouldn't let me dyno/sniff the car, they were insisting on OBD-II compliance (even they I dyno/sniffed last time around)
In the future I'll either just run sims and 2 O2's or have all 4 O2's installed (get an extra set of bungs welded in).
Old Jun 2, 2008 | 03:25 PM
NmexMAX's Avatar
dot dot dot ...
Myself and 1 other member are using our secondaries w/o any cats / sims /extensions, and do not throw codes for them. Which means that even w/o cats they do not get tripped, nor does their position matter in the exhaust stream matter, meaning you could add a couple of bungs anywhere that is convenient w/o having to extend them to reside behind the main cat.
Old Jun 2, 2008 | 04:56 PM
Thanks, that's what I was hoping for.
maxinout93
Oct 27, 2015 01:29 PM
Blackwind
Aug 5, 2015 06:35 PM
bassmann
Aug 3, 2015 07:53 PM
