Passenger Power window does not work
Old May 30, 2008 | 01:51 PM
playtoy's Avatar
Model:
Maxima GLE 2000
I can put down and up the Passenger window from the driver side no problem. But from the Passenger side itself the switch doesnt work, window will not go down nor up. However the button for the power lock works on the passenger side. Is the switch broken on the passenger side? If so from what site can I pick one up from.
Thank in advance.
Old May 30, 2008 | 02:19 PM
jasonmax's Avatar
Originally Posted by playtoy
Model:
Maxima GLE 2000
Thank in advance.
you can get everthing for your car from Dave.
Old May 30, 2008 | 05:02 PM
playtoy's Avatar
Dave? Does he have a site?
Old May 30, 2008 | 05:09 PM
jasonmax's Avatar
This is his phone#.
888-254-6060
he's offering discount at the end of this month.
http://forums.maxima.org/showthread.php?t=563086
Old Jun 23, 2009 | 06:47 PM
playtoy's Avatar
This is a old thread that I started so since I am going to talk about the same issue, I am bringing this one back to life.
Issue
So I order two new switches for the passenger side and the back window but I noticed that for a couple of months now, on the passenger side I can bring the window up but not down.
Is this still a switch problem? I havent installed the new switches yet as I am scared that it will blow up again. What I mean by again, well I took a working switch from the back window and installed it on the passenger side and about 2 months after it stop working and now you can only bring the window up.
Is there any other thing I can test out before I take the chance and change the switches as these were not cheap at all.
Thank You
Old Jun 24, 2009 | 06:33 AM
bigpopaj369's Avatar
i have the same problem with my 00se the pass window rarely goes down with the switch but goes down fine with the driver control.
Old Jun 24, 2009 | 08:51 PM
greg989's Avatar
I have a similar problem, my passenger window only goes up with the passenger window control and wont do anything with the driver control. I'm thinking i have a bad master switch or something. If someone could shine some light on this that would be great.
Old Jun 25, 2009 | 07:44 AM
Deckdout2's Avatar
Play with my balls
That's odd. Sounds like the switch or the motor. I have some window parts out of an 03 if you are in need of one.
http://forums.maxima.org/5th-generat...st-chance.html
Old Jun 25, 2009 | 07:47 AM
pariah07's Avatar
Yeah, I got the same problem withe my 2000 SE. So is it a switch issue or what?
Old Jun 29, 2009 | 10:17 AM
playtoy's Avatar
So you guys have the same issue, the window goes up but not down. I have two bran new switches but I do not want to install them just yet as it was working when i changed it from back to front and then now it only works up not down.
Old Jun 30, 2009 | 07:30 PM
greg989's Avatar
Not sure i have a new passenger switch on the way, i will let you know after i put it in.
Old Jul 2, 2009 | 05:35 AM
playtoy's Avatar
How much did you end up paying for it?
jerrod99_se-l
Aug 27, 2015 08:27 PM
george__
Aug 18, 2015 07:06 PM
KGMtech
Aug 18, 2015 09:21 AM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
