How to clean MAF under $10 w pics
Old Jun 12, 2008 | 02:01 PM
  #41
MikeyC1027's Avatar
I'm planning on doing this later, but am confused by one step. What is the purpose of the pipe? You say to "Take you MAF cleaner and put the pipe on it, so you can reach small areas. When you clean the MAF, DO NOT touch anything in side the tunnel with the pipe because that can damage the sensor." ?? Do I spray the pipe and insert it into the tunnels? How do I apply the cleaner to the side of the tunnels without physically touching them? Do i just spray the entire thing down including the tunnels? Can someone please clarify this for me?
Old Jun 12, 2008 | 03:46 PM
  #42
jasonmax's Avatar
you put the red pipe/straw on the can.
the pipe makes the spary more focus and stronger and easier to point.
don't touch anything on the maf when you cleaning it.
don't spray the entire thing, just tunnels.
Old Jun 12, 2008 | 03:57 PM
  #43
MikeyC1027's Avatar
Oh OK gotcha...Tyvm for clearing that up as well as posting this How-To
Old Jul 27, 2008 | 10:14 AM
  #44
Nicktard's Avatar
How do you perform the ECU reset and Idle relearn procedures? I've also heard that some people use brake parts cleaner, it dosn't leave resin. They said that the MAF cleaner will leave that oil on it and it can mess up the sensor later on.
Old Jul 27, 2008 | 12:08 PM
  #45
jasonmax's Avatar
there is no oil in the cleaner. where does that come from?
reset procedure, please search.
Old Jul 27, 2008 | 01:45 PM
  #46
johnnyd2k2's Avatar
Is the idle relearn procedure nessacary I read a few people say they didn't do it so what are the pros of doing this PIA procedure
Old Jul 27, 2008 | 03:57 PM
  #47
Nicktard's Avatar
I took it out....and noticed that I dont have the metal piece around the front. What kind of problem is this?
Old Jul 27, 2008 | 05:23 PM
  #48
jasonmax's Avatar
00-01 maximas don't have this transitor IIRC.
Old Jul 27, 2008 | 05:25 PM
  #49
jasonmax's Avatar
infact, I believe the engine will get used to the cleaned MAF sooner or later, but doing the relearn and reset won't hurt, right?
Old Jul 27, 2008 | 06:05 PM
  #50
Nicktard's Avatar
Thats good new about the resistor. idk about anyone else but whenever i work on my car...i finish the job and something else goes wrong in this case....cleaned my MAF, Put in a new dome light...and then I blew my ballast for my fog lights. great...no what
Old Jul 27, 2008 | 06:22 PM
  #51
Maxgig's Avatar
Man I don't believe it's that easy. I actually paid to have that done before I moved to AL.
Old Jul 29, 2008 | 02:51 PM
  #52
BARBARIUS MAXIMUS's Avatar
wish i would have saw this before i changed mine
Old Jul 29, 2008 | 08:06 PM
  #53
damerbullet's Avatar
Great pictures! Great write-up!
Two-thumbs up!
Thanks!!!
Old Aug 19, 2008 | 11:38 PM
  #54
OC guy's Avatar
2002 maxima se
Can we also spray on that little metal wire transitor IIRC in the middle or whatever it called? and what is the resistor thing?
Old Aug 20, 2008 | 07:31 AM
  #55
NmexMAX's Avatar
dot dot dot ...
Spray the hell out of everything.
Old Aug 21, 2008 | 12:00 PM
  #56
jasonmax's Avatar
that's the air temp sensor.
Old Aug 24, 2008 | 01:06 PM
  #57
shiftyse's Avatar
Hey guys, New-B here though this is my 2nd maxima. I have a 2000 SE 5spd. Prior to cleaning the MAF using the steps above I had a CEL, intermittent stalling and a code P0430. I used my friends Snap-On Scanner to look at the O2 sensors and Bank 1 sensor 2 was "frozen" After cleaning my MAF and driving approx.20 miles, the CEL and the stalling are both gone. I haven't been able to get the scanner on the car yet to see if bank 1 sensor 2 is actually working or not. Is it possible that a dirty/contaminated MAF could have caused the code and the stalling. Thanks for entertaining a new-b question.
Old Aug 24, 2008 | 02:15 PM
  #58
jasonmax's Avatar
I don't think the MAF will cause stalling, but it could be the problem although an engine will run w/o a MAF. did you let the cleaner dry before putting the MAF back?
Old Aug 24, 2008 | 06:01 PM
  #59
tbonesteak's Avatar
will be doing this coming weekend. Thanks!
Old Aug 25, 2008 | 12:17 AM
  #60
ryant35's Avatar
I just did this but before I saw this thread and I took out my entire air box... I guess it saved me having to buy a torx screwdriver.
Old Aug 25, 2008 | 12:18 AM
  #61
ryant35's Avatar
My car was stalling at idle before I cleaned my MAF, now it's fine and more responsive.
Old Aug 25, 2008 | 02:58 PM
  #62
metalpiotr's Avatar
03 Maxima, 6spd
My car started stalling right after being started when warm, so I cleaned my MAF. It did not make the problem go away, but I honestly do feel like I got some power and responsiveness back.
Old Aug 25, 2008 | 04:18 PM
  #63
shiftyse's Avatar
Hey New-B here, I did let the MAF dry completely before re-installing it. I have driven the car about 45 miles now and the CEL is still out however on the way home today, the car started stalling again as soon as I put the clutch in. The wierd thing is, if I shut the car off for about 1 minute or so and re-start it, the car idles fine. Any ideas before I resort to the dealer????
Old Aug 25, 2008 | 05:52 PM
  #64
jasonmax's Avatar
codes?
I don't think it the cleaning that cause the stalling cuz mine is fine. should be a coinsidence.
Old Aug 25, 2008 | 05:54 PM
  #65
jasonmax's Avatar
maybe it's the O2 sensors?
Old Aug 25, 2008 | 06:54 PM
  #66
metalpiotr's Avatar
03 Maxima, 6spd
wouldn't those throw some codes?
I have a thread on it here:
http://forums.maxima.org/5th-generat...ease-help.html
don't want hijack this one. btw, this is a great thread with good pictures, Jason. I'm definitely glad I cleaned the MAF sensor.
Old Aug 26, 2008 | 12:41 PM
  #67
represent24's Avatar
on a 4th gen., wouldn't you spray everything in the in the short tubing with MAF cleaner, including the temp. sensor?
Old Aug 26, 2008 | 01:32 PM
  #68
mist max2000's Avatar
when i did my 2k maf i sprayed the hell out of everything.. even the screen lol
Old Aug 26, 2008 | 06:01 PM
  #69
adamgh81's Avatar
wannabe max mechanic
jasonmax, any chance you can get those pics working again. I'm planning on doing this on my day off this week. Thanks, looks like a great write-up!
Old Aug 26, 2008 | 07:17 PM
  #70
Kevin319's Avatar
I have been getting 13-14 mpg on my 00 Max se auto, hopefully this will clear things up. Thanks alot!
Old Aug 26, 2008 | 07:43 PM
  #71
jasonmax's Avatar
aren't they working? they look working to me.
Old Aug 27, 2008 | 12:49 AM
  #72
PhalC1's Avatar
I did this the other day, but I havent noticed any difference.
Does any one know if they do it at the dealership when you buy a certified used car?
Old Aug 27, 2008 | 10:22 AM
  #73
adamgh81's Avatar
Sorry man, it was probably my work blocking the pics.
Old Aug 27, 2008 | 09:03 PM
  #74
02_Maxima_6sd's Avatar
nice write up!!!!
Old Aug 28, 2008 | 03:40 PM
  #75
Kevin319's Avatar
I tried to disconnect the MAF today by pressing on the socket and pulling upwards. It wouldn't budge a bit. Did anyone else have a difficult time disconnecting it? Also, will my car start if I don't do the ecu reset?
Old Aug 28, 2008 | 03:49 PM
  #76
jasonmax's Avatar
you could wiggle while pulling, but that thing is weather proved, so it should be tight.
it will start.
Old Aug 28, 2008 | 03:56 PM
  #77
Kevin319's Avatar
Thanks for your quick response, I was also a little hesistant of starting this clean up process because I did not know how do the ecu reset (kept failing) I will try again later.
Old Aug 28, 2008 | 05:15 PM
  #78
Kevin319's Avatar
I hope you don't mind me posting a picture in your thread but this is what my thingy looks like ...
I can press the socket and push it down at the same time. I tried to pull it out in every way possible way but seems like its not going to let itself go. Any suggestion?
Old Aug 28, 2008 | 08:38 PM
  #79
ryant35's Avatar
Push a small flat head screw driver inside that space behind the tab, and push it towards the top of the picture and pull it up with your other hand. It's opposite of everything you would expect from a connector on this car.
Old Aug 28, 2008 | 10:51 PM
  #80
theStig's Avatar
thanks for the write-up. I'm a firm believer in cleaning MAFs but I think i've been doing it wrong.. Last time i had the MAF out of the car, i just sprayed the little wire/resistor bit thinking that would do it.
If one runs the stock airbox/filter, what are the chances the MAF will even get dirty? My 2002 has been bogging for years now.. I would estimate its down a good 30-50hp, just haven't had time to investigate the issue since (until recently) it's been the wifes car. Now that it's my beater, I've got to de-woman-abuse the car one thing at a time.
