O2 sim install question
Old Jun 12, 2008 | 09:09 AM
miksen's Avatar
FU, FU, FU, You're Cool..
So I installed my 02 sim and want to make sure I did this correctly.
I put everything "inline" white,black,red on one of the sensors and just white on the other primary sensor.
I guess my question is should I have cut the sensor wires completly? instead I stripped a portion of the sensor insulation and wrapped the o2 sensor wire around it?
the install directions are a little confusing to me.
Old Jun 12, 2008 | 10:15 AM
Puppetmaster's Avatar
You are supposed to cut the signal wires on the harness completely, if not you won't really be intercepting the signal.
http://forums.maxima.org/showthread....ghlight=o2+sim
Old Jun 12, 2008 | 10:21 AM
machinehead131's Avatar
Yes the purpose is to simulate the signal, cut the wires completely as Puppet has said.
Old Jun 12, 2008 | 10:26 AM
NmexMAX's Avatar
dot dot dot ...
Is it easier to sim them or add a bung?
Old Jun 12, 2008 | 10:59 AM
Old Jun 12, 2008 | 11:29 AM
rmh3093's Avatar
Only gentoo powered Maxima!
Adding a sim is dead easy and probably easier to hide...
Old Jun 12, 2008 | 01:25 PM
miksen's Avatar
Puppet, Thanks for the help your writeup is spot on THANK YOU!
Old Jun 12, 2008 | 01:37 PM
choiiiiiiiiiii's Avatar
why would you need to hide a bung...?
Old Jun 12, 2008 | 03:03 PM
Scottwax's Avatar
That's Mr. Detail to you
Some emissions inspectors actually know what to look for, I guess.
PH98I30
Jan 9, 2025 08:08 AM
homeyclaus
Sep 3, 2015 06:15 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
