Some CEL p codes help
Old Jun 29, 2008 | 12:54 PM
foxracing12's Avatar
My uncle has a 2002 se, that recently failed inspection for a check engine light. It had a code that said camshaft actuator on bank 1, and then a code for an 02 sensor and one more for manufacturer ctrl air metering (probably caused by the others).
I assume the cam actuator relates to the variable valve control or something, but I think the motor is mechanically perfect. Could this code be triggered by an o2 sensor? I did a search and found similar but not exactly the same cases. Thanks for any input.
Old Jun 30, 2008 | 05:40 PM
pmohr's Avatar
No more Maximas...
Why do you think the CVTC assy is mechanically perfect?
What's the manufacturer code that showed up? And which O2 sensor code?
For a proper diagnosis, you really need to post up all of the error codes themselves, not just a vague description of what they might have been.
Old Jul 1, 2008 | 02:50 PM
I think its functioning properly because of bulletins I read describing a rattle noise when it is malfunctioning. The engine sounds perfect so I partly assumed this was ruled out for now. As for the codes, I am going off of memory as the retard at autozone printed the wrong p codes and I no longer have the car. If the CVTC is in fact working properly, are there any sensors that could trigger that plus an 02 sensor code?
jmlee44
Oct 2, 2022 02:13 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
