P1126 Code - Thermostat or Relay?
Old Jul 3, 2008 | 08:05 PM
cabernet's Avatar
Search of the internet turned up two possible causes for P1126 - one is for a bad or leaking thermostat and the other a defective relay. Has anyone had this code and what did they replace to fix it? Thanks in advance.
I also read during the search that the Maxima has 2 thermostats - one a generic replacement and one a dealer only replacement. Never heard of something like this before.
Old Jul 3, 2008 | 08:39 PM
NmexMAX's Avatar
dot dot dot ...
What year is your car? I'm assuming 00-01. The codes aren't interchangeable between years. For a 00-01 it's a t-stat, and for 02-03, it's a throttle relay.
If it's an 00-01, then get a new t-stat. Dealer / Autozone / etc, cheap part, fairly easy to install. Follow the coolant hose from the radiator on the right side (pass) of the engine, on top of the idler pulley you use to adjust the belt tension.
Old Jul 4, 2008 | 10:23 AM
pmohr's Avatar
No more Maximas...
According to past posts, he has a 5th gen.
As NmexMax said, replace the main thermostat, see if that fixes the problem.
Yes, the DE-K has two thermostats, same style as the VQ35 Pathfinders (decent actual pics can be seen here: http://www.z1motorsports.com/350_g35...6deqj0nrft2oj1 )
Old Jul 4, 2008 | 10:59 AM
cabernet's Avatar
Thanks, and yes it's a 2000 Max.
Miket2006
Mar 1, 2021 03:55 AM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
zmcneely13
Sep 26, 2015 02:26 PM
