5th Gen ECM Swap Question
Old Jul 16, 2008 | 07:53 PM
rdoug26's Avatar
Does anyone know if a ECM from a 2000 CALI MT will work properly in a 2001 CALI MT??
Old Jul 17, 2008 | 06:12 AM
NmexMAX's Avatar
dot dot dot ...
It should, but as we all should know, you will need to get it (ECM) programmed to YOUR key.
What's the situation here that prompts this question?
Old Jul 17, 2008 | 08:14 AM
rdoug26's Avatar
Thanks... I figured it would work. As I looked at the O2 sensor diagram, they looked the same. Reason for this is, I'm trying to sell the ECM. My car was swapped from AUTO to MT a while back and the mechanic used the wrong ECM. I have resolved my issues and I'm trying to pass this ECM on to someone who could use it. The question came up about using it in a 2001.
Thanks again...
Old Jul 18, 2008 | 01:05 PM
rdoug26's Avatar
Just to clarify, my car is FEDERAL spec
Old Oct 10, 2008 | 01:57 PM
NismoCefiro's Avatar
How do you tell if the ECM is for cali or fed spec? I purchased a used ECM for my swap. I have an I30 which is all cali spec. Will the manual ecm work? What about the swirl?
Here is the VIN for the ECM
JN1CA31D2YT744807
Old Oct 10, 2008 | 02:14 PM
pmohr's Avatar
No more Maximas...
JN1CA31D2YT744807
Your ECM is from a '00 GXE, 5 speed, Cali.
Old Oct 11, 2008 | 03:59 AM
Whats the best way to get the ecm programmed for my key? The dealer says the ecm must be in the car to program. If I send it to jim wolf, can the disable IMMU?
Old Oct 11, 2008 | 04:01 AM
pmohr's Avatar
No more Maximas...
Yes, it must be in the car and hooked up to program it.
No, JWT can not get rid of the NATS system.
Old Oct 11, 2008 | 04:28 AM
hmmm, so im kinda at a catch 22? I want to do the swap with no dealer interference, however i need them or i cant start the car. Can I bring the key in and have it programed for that vin and use that to start the car? The data is verified in the ecm but is it stored anywhere in the receiver on the ignition? Is the id stored in the secu?
tsi6001
Oct 3, 2022 10:23 PM
Finkle
Sep 27, 2015 09:53 PM
ChrisIve
Aug 22, 2015 03:04 PM
maxima-junky
Aug 13, 2015 09:59 AM
Blackwind
Aug 5, 2015 06:35 PM
