Easy one: Battery Ground
Old Jul 19, 2008 | 10:59 AM
MDeezy's Avatar
Working on a 5th. Does the batter ground to that small 10mm bolt hole on the tranny? If so then my problem lies elsewhere
Used to the 4gs that bolt up to the heads.
Old Jul 19, 2008 | 12:00 PM
sublime258's Avatar
I grounded my battery to the bolt right next to the battery (already has something else grounded to it). If you are facing the front of the car, it would be to the right of the battery (might have to take battery out to get to it). This is from Shinjiduo's instructions which came with the kit.
Old Jul 19, 2008 | 12:53 PM
MDeezy's Avatar
I'll look for that location. but is the stock location that stop on the tranny?
Old Jul 19, 2008 | 10:00 PM
MDeezy's Avatar
no one knows where the stock ground for a 5.5th gen is? just gotta pop the hood andn follow the negative terminal battery....
Old Jul 19, 2008 | 10:10 PM
n3985's Avatar
大陆弟弟
The line goes from engine block to chassis ground behind the battery to the actual battery. The tranny ground goes from tranny to another chassis ground by the starter.
Old Jul 19, 2008 | 10:12 PM
MDeezy's Avatar
okay that what I was wondering. I thought that hole on the tranny (close to the tranny) was for the battery ground. its threaded.
its goes on the engine block on the heads? can you give a description of where? because my friends 2k3 battery ground wires doesnt reach far enough to the block.
Old Jul 19, 2008 | 10:15 PM
n3985's Avatar
大陆弟弟
It's on the block, by where the tranny dip stick is IIRC.
Old Jul 20, 2008 | 06:49 AM
MattyBlacc's Avatar
well....i tried starting the car again today.
the motor finally turned over a little bit. then i lost all power. i turn the key back on and then i got all power back. kept trying to crank it up a few more times and now the starter is smoking really bad.
Old Jul 20, 2008 | 06:54 AM
MDeezy's Avatar
not sure where the dipstick would be located... working on an MT.
Old Jul 20, 2008 | 08:38 AM
metalpiotr's Avatar
03 Maxima, 6spd
don't think a MT has a dipstick.
Old Jul 20, 2008 | 09:50 AM
MDeezy's Avatar
nah it doesnt but I'm not familiar with where they put it on an AT. Havent really worked on a 5.5th gen too often.
Old Jul 20, 2008 | 04:38 PM
pmohr's Avatar
No more Maximas...
Look directly behind the left hand head. There's a bracket bolted on to the coolant log, onto which the ground cable from the battery is bolted.
At least, that's how it is with Merlyn's but we've messed with that thing so much...
Old Jul 20, 2008 | 05:50 PM
MDeezy's Avatar
Thanks! I saw that and bolted it to it. That helped greatly. Motor need more TLC so, gotta spend some more time on it.
thanks all!
Old Jul 20, 2008 | 07:42 PM
MattyBlacc's Avatar
problem solved.....thanks for all your help peoples!
Old Jul 21, 2008 | 08:29 AM
Mattlikespeoples's Avatar
i didn't say anything... hmmmm
Apr 16, 2020 05:15 AM
bigfrank
Oct 1, 2015 12:51 PM
