P0132 O2 Sensor Code
Old Jul 26, 2008 | 07:22 PM
sampimpinthug's Avatar
Hey guys I am getting a P0132 O2 Sensor code in my 00 maxima. I know you're going to tell me the image and the codes are stickied, but the problem is I have a Fed spec Max. The image which is stickied is for a Cali Spec. Max. I am trying to purchase the O2 Sensor from rockauto. Can anybody please tell me which sensor do I have to exactly get(It would be great if you could give me a part number from rockauto.com, and a bosch part number, they are the cheapest XD). If not, could I atleast know if it is upstream or downstream and if it is front or rear and left or right? I am guessing the sensor which is needed to be replaced is bank 1.
Your help is much appreciated. Thanks in advance.
Old Jul 26, 2008 | 07:33 PM
jasonmax's Avatar
http://forums.maxima.org/5th-generat...ing-codes.html
Old Jul 26, 2008 | 07:59 PM
Professor's Avatar
Its the front one, I used a adjustable wrench to break it free after i got it hot, came right out, put in new one, cleared codes, new filter and cleaned maf, good as gold.
Old Jul 27, 2008 | 10:40 AM
thanks Jason max but like I said in my thread I already saw the sticky but it is for Cali spec and I need an Image for fed Spec. Professor could you tell me exactly where it is located and which one am I suppose to get? I went on rockauto.com and there are so many different kinds.
Old Jul 27, 2008 | 11:19 AM
VQP0WER's Avatar
http://www.courtesyparts.com/betasit...1988_1992.html
Old Jul 27, 2008 | 04:13 PM
Thanks a lot VQPOWER, clears a lot of things. I see the whole diagram, now which is the Bank 1 Sensor 1? front or rear? left or right? Before or after the cat?
Thanks.
EDIT: If someone could pull out a bosch part number, that would be great. The error code is P0132
Thanks.
Old Jul 27, 2008 | 04:48 PM
VQP0WER's Avatar
Rear bank, before cat if I'm not mistaken. It will be the one with the black wire harness.
http://www.courtesyparts.com/betasit...l-p-45528.html
Old Jul 27, 2008 | 04:57 PM
you think maybe dave could get it cheaper? and I heard we get a discount on courtesyparts if we mention the forum's name.
Old Jul 27, 2008 | 04:58 PM
VQP0WER's Avatar
Yep, call DaveB. Not sure if anyone at Courtesy Parts will give you a deal or not.
Old Jul 27, 2008 | 05:04 PM
Is it okay if I get the Bosch universal type? what's the disvantage of getting a universal as oppose to OE?
How about 15726Oxygen Sensor - Univ Type Before Catalyst Two required; exc. Calif.; Check / Replace Interval: 100,000 Miles(Except California Emissions; Rear; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles; Universal Type - Upstream
Except California Emissions; Front; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles; Universal Type - Upstream)
Or even the OE type of BOSCH which is 13350Oxygen Sensor - OE Type Before Catalyst Rear; Calif.; Check / Replace Interval: 100,000 Miles
msellas
Sep 23, 2015 09:16 PM
homeofbacon
Sep 23, 2015 07:17 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
