Disconected battery, cluster not working now..
Old Aug 22, 2008 | 06:50 PM
Goran's Avatar
Hey guys,
Just need little help here. Last week before i changed the oil I used seafoam and once i was done, had a check engine light on so i disconected the battery. Once i hooked it back up, my cluster went out. It shows that I am running empty all the time and my speed/rpms don't work. Also, it doesnt show my mileage. Tried to reset the battery again, checked all the fuses but no luck. Any suggestions what might be the problem?
thanks
Old Aug 22, 2008 | 07:14 PM
Goran's Avatar
it's not showing my car for some reason. it's a manual 02 max if that matters
Old Aug 23, 2008 | 10:31 PM
wyche89's Avatar
i have no idea man.. but heres a free bump to the top to give you some more attention
Old Aug 24, 2008 | 08:50 AM
VQP0WER's Avatar
Not sure if there are any fuseable links, but check the schematics, if none, replace your cluster.
Old Aug 24, 2008 | 08:58 AM
Drockb418's Avatar
my friend kinda has the same prob
http://forum.e46fanatics.com/showthread.php?t=591847
Old Aug 24, 2008 | 10:09 AM
jasonmax's Avatar
I think there is a fuse you should take a look at inside the fuse box.
Old Aug 31, 2008 | 10:46 AM
Goran's Avatar
yea i looked into it little bit more but no luck. I was planning to take it to stealership but dont really wanna get ripped off. You guys think it would get fixed if i get a new cluster? Is the mileage stored in ECU or cluster, would it show my original mileage if i put a new cluster in?
Old Aug 31, 2008 | 10:59 AM
VQP0WER's Avatar
Nope, mileage is stored in the cluster. I you do swap the cluster out, I believe you have to go by the motor vehicles department and sign a affidavid stating the true mileage or something like that.
homeyclaus
Sep 3, 2015 06:15 PM
tnewbs
Aug 28, 2015 10:15 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
doobadoo
Aug 15, 2015 06:43 PM
kenc15
Aug 5, 2015 08:29 AM
