Brake pads interchangable between generations?
Old Nov 8, 2001 | 06:34 AM
Jeff K's Avatar
I know that the front brake pads are the same for the 4th gen('95-'99) and 5th gen('00-'01). Does anyone know yet about the '02s? All you '02 owners out there I need one of you to see if the pads are a different size. Nissan says the rotors are larger but that might not mean the pad changed.
www.nissannews.com
The Maxima's "cut above" performance is reinforced by a refined engine-speed-sensitive power rack-and-pinion steering and enhanced 4-wheel disc brakes with 16 millimeter larger front discsand 4-wheel/4-channel/4-sensor Anti-lock Braking System (ABS).
Old Nov 8, 2001 | 07:31 AM
i•maxx's Avatar
Good Question!
I think I'll call my mechanic at the dealership and find out
Old Nov 8, 2001 | 06:24 PM
got rice?'s Avatar
contact the local dealer and have them check the part #s
Old Nov 8, 2001 | 07:01 PM
RussMaxManiac
Re: Brake pads interchangable between generations?
To be exact, they are not the same for 95-99 to 00-01. 5th gen pads are a bit wider and thicker (surface area), the actual backing is the same size. So they will fit both gens.
www.nissannews.com
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
