Uneven heat thru vents
Old Sep 18, 2008 | 11:53 AM
mike_747's Avatar
I have a 2000 SE with automatice climate control and just noticed that the temp is way cooler on the passenger side dash vents than the drivers side.
Anybody have this problem? Know of a fix? My mechanic did a search and there are no TSB's on this.
thanks
Mike
Old Sep 18, 2008 | 01:09 PM
PearlWhtMaX2000's Avatar
custom dual climate control.....
I wouldnt worry about it, as long as you as the driver are comfortable
Old Sep 18, 2008 | 01:46 PM
Feldman's Avatar
i agree, screw the passenger!
Are you getting the same flow from the passenger side as you are on the driver side?
How about if you turn the a/c on what happens then?
Old Sep 18, 2008 | 02:10 PM
mike_747's Avatar
A/C
The A/C is not affected, just heat. As I drive alone most of the time it isn't a real big deal, however when it gets cold (yes it does in Seattle) you do want
max. heat at times.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
captchaos
Mar 15, 2016 12:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
