What in the name of god has happened to my car!!? Valve help!
Old Sep 27, 2008 | 05:20 PM
  #41
Kevin319's Avatar
Try a 20z bottle of Chevron TECHRON Fuel System Cleaner, its only about $11 ($8 for 12oz) a bottle. It should reduce valve noise by a large amount. Worth the try ...
Old Sep 27, 2008 | 07:49 PM
  #42
VQP0WER's Avatar
Cylinder topping out?
Old Sep 28, 2008 | 07:11 AM
  #43
Dave2112's Avatar
VQPower, are you trying to drive me to suicide? You seem dead set on throwing a monkey wrench into my life right now.
Kevin, will do. What I dont get is the car has had nothing but good gas all its life, with semi-regular Seafoam additions, it can still get build-up?
UPDATE: I changed my PVC Valve yesterday, 115k on the old one, and I swear to god, I havent heard the first ping yet. Im taking the car out when it warms up tday and we'll see what happens. Anybody ever heard of the PVC valve causing engine noise ect?
Old Sep 28, 2008 | 07:25 AM
  #44
Kevin319's Avatar
All I know is that you will build carbon deposit no matter which gas you use. It probably doesn't have to be from the gas you use... could be something else ...
Old Sep 28, 2008 | 09:10 AM
  #45
allblackmax96's Avatar
your pcv takes crankcase pressure and relieves it into the intake manifold and you can get oil(usually do) into the intake manifold, the oil will lower the volitility of the fuel and cause knocking. you should look into the home depot oil catch can, which catches that oil blowby in a canister and helps prevent detination. its real cheap and could help out with your problem.
Old Sep 28, 2008 | 11:24 AM
  #46
VQP0WER's Avatar
Ha...just playing with ya a little.....
Old Sep 28, 2008 | 03:20 PM
  #47
2002 Maxima SE's Avatar
Is this a VQ35?
If so, check your VAIS valve (passenger side of engine). I've seen two posts ,over 4 years, where the VAIS valve screw came loose and can cause some pretty nasty noises.
Old Sep 29, 2008 | 05:21 AM
  #48
Dave2112's Avatar
Sounds good.
Old Sep 29, 2008 | 05:25 AM
  #49
Dave2112's Avatar
Awesome, Yeah I saw Irishes write up on it sometime ago. It seems that should be the next step, although since changing my PVC valve Ive noticed no pinging, and I seemed to have gained some power or something. Not sure if this is mental but it seems to have helped. Either way, the Oil Catch-can is my next step regardless.
Old Sep 29, 2008 | 05:30 AM
  #50
Mizike's Avatar
I also notice the "rattling" on the downside of revving the engine when the RPMs are going back toward idle.
  #51
Dave2112's Avatar
I can appreciate your cup is half empty humor haha
Old Sep 29, 2008 | 05:32 AM
  #52
Dave2112's Avatar
Originally Posted by 2002 Maxima SE
Is this a VQ35?
Any links? How would I get to the VAIS Valve?
Old Sep 29, 2008 | 01:55 PM
  #53
crazy97's Avatar
I have discovered a heat shield that wraps around the pipe right before the flex section has rusted off its weld and looks like it can cause some noise. I also changed my Fram filter back to the Nissan one and poked around at the heat shield... Now the noise has quieted quite a bit. It is also cooler outside, so who knows..
Anyone want to see a picture of this?
Old Sep 29, 2008 | 02:03 PM
  #54
dkillahster's Avatar
I do
Old Sep 29, 2008 | 02:10 PM
  #55
crazy97's Avatar
Originally Posted by dkillahster
I do
I will have to crawl under it again with a camera this time.. I should have a picture by sometime tonight.
Old Sep 29, 2008 | 02:49 PM
  #56
Just do search on VAIS.
The VAIS (Variable Active Intake System) is on the passenger side of the UIM. It has a small arm that is vacuum activated. You can remove it without removing the UIM to check the screws.
Old Sep 29, 2008 | 05:08 PM
  #57
Dave2112's Avatar
Your effort is much appreciated
Old Sep 29, 2008 | 05:13 PM
  #58
Dave2112's Avatar
OK, I'll look for it, thank you!
Ive been hearing some pinging today, not near as bad as it was last week but still audible. Id like to think the PVC Valve helped but Im still getting a little bit of noise. What do you think VQPOWER? Do you think my Transmission is going to need replacing? Wiper Motor maybe?
Old Sep 29, 2008 | 09:13 PM
  #59
crazy97's Avatar
Heres what I found.. It appears that at one time this was tack welded in place and has now rusted away and is able to slide around and cause rattling noises.
Old Sep 30, 2008 | 05:10 AM
  #60
Mizike's Avatar
When cruising at low speeds (15-20 mph) as mentioned earlier, I noticed that if I shift into neutral, the rattling stops. Wierd. I will also check to see if I have any lose exhaust pieces rusted away. Im in the south and dont normally have much to worry about when it comes to rusted pieces. My fiancee's Altima had that same piece break away from the weld. I had it re-welded and fixed the problem.
Old Sep 30, 2008 | 06:00 AM
  #61
Also, if it is truly a light ping (around 40 to 45mph and under 2500 rpm with light to no throttle) it is normal. Mine started doing it around 40K. The theory is that oil blowby via the PVC lowers the octane in the combustion chamber. PVC blowby is greatest at low rpm.
A catch-can will cut down on it, but not eliminate it completely.
Old Sep 30, 2008 | 09:20 PM
  #62
Dave2112's Avatar
That sounds exactly like whats happening with my Max. If Im easying along I'll get some ping(sometimes), but if I get into the gas its gone. Im going to work on gettng my catch-can installed this weekend.Thanks for the info.
Old Oct 2, 2008 | 09:53 AM
  #63
Mizike's Avatar
bump
Old Oct 7, 2008 | 05:07 AM
  #64
Mizike's Avatar
bump for updates...
Old Oct 8, 2008 | 06:01 AM
  #65
russianguy's Avatar
What this means though is removal of the outer timing cover, and than the primary and secondary chain assembly's. It's a PITA job in the car, probably the most advanced one that doesn't nescessatate engine removal. Removal of the upper oil-pan is highly recommended, allthough out of the 6 times I've removed a vq outer cover in the car without dropping the pan I haven't had a single leak long or short term except for on the 6th time! BUT the guy demanded to pick the car up way early and might be trying to scam me/not have a leak as well, it's a ****ty/sketchy story. But expect to pay between $850-$1400 in labor alone.
i demanded to pick the car up? or you offered me 40 dollars to leave because you "had a lot of stuff going on". hmm you happen to be driving my car when you showed up to your garage after you told me that the car needs to sit for 24 hours ... thats odd , and you were gonna send me home 4 1/2 hours away with idle issues and a loose accesories belt. oh and lets not forget the oil leak that is very much real. 1 week after that you were going to come to my house and fix the oil leak with my brothers tools ... but you never showed uo or called me back since. i would like to resolve this.
Old Oct 8, 2008 | 09:52 AM
  #66
Crasher's Avatar
Hey somone at the NISSAN DEALER told me that "yea valve ping in those 3.0 liter engins is just a characteristic dont worry about it." What an idiot. Anyway changing all the coils is what eventually fixed mine. Sometimes the misfires will not always register with the computor and give an light.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 16, 2015 01:19 PM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 7, 2015 04:20 PM
