code p0420 and TSB 00-070B
Old Sep 30, 2008 | 05:30 PM
jhay's Avatar
Hi - Just pulled a code for P-0420. I've been searching around and it looks like there is a TSB 00-070B written up back in June of 2004. I found the "A" version but can't find this "B" version. Does anyone have any insight to the changes in the "B" version?
Jim
Old Sep 30, 2008 | 05:41 PM
johnnyd2k2's Avatar
I fixed this code by cleaning up the ground wires for the sensor and reset the ecu. It's been 2 months now and it hasn't come back and no pending codes either. Also check yur oil make sure you're not overdue for a change this could also cause that code.
Old Sep 30, 2008 | 05:45 PM
jhay's Avatar
Hey Johnny - Thanks for the response. The car is a 2000. You mentioned an oil change can pop this code?
Jim
Old Sep 30, 2008 | 06:47 PM
johnnyd2k2's Avatar
Old dirty oil can cause the sensor to misinterpet data if memory serves me correctly I'll see if I can dig up the thread where I found the info for you.
Old Sep 30, 2008 | 06:58 PM
SoonerFan's Avatar
Cletus
ive had it on and off for over a year....ill erase it and it wont come back for weeks...sometimes it comes on and goes off itself after a few days.
Old Oct 1, 2008 | 05:37 PM
jos's Avatar
jos
How/where did you clean the ground wires?
Old Oct 1, 2008 | 05:49 PM
johnnyd2k2's Avatar
I only did the front sensor grounds but once you take off the engine cover and locate the sensor just trace the two wires they are grounded to the intake manifold(I think) but they are right next to each other on the passengers side they are lined up front to back you will see them. Just use a wire brush or some fine sandpaper and clean them till they are shinny again mine were slightly coroded.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
