100k mile club :-D
Old Oct 3, 2008 | 09:05 AM
nismomaxx's Avatar
100k mile club :-D
I was actually wondering since my car just hit 99,001 I was wondering if maybe someone could give me some ideas on what I should do to make sure my car is straight at 100 - like a 100k mile service what should I doo?
Old Oct 3, 2008 | 09:07 AM
vinco's Avatar
Start expecting O2 sensors, coilpacks, and MAFS to go out. Struts also.
Old Oct 3, 2008 | 09:14 AM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
after 100k i changed, some O2 sensors, axles, tie rods ends, and will change spark plugs soon. I also cleaned my MAF with that spray for $6, there's a thread here some place, that helped a lot, and throttle body clean if you want. I'd consider getting a ground kit if you dont already have one, it makes the idle sooo much smoother.
Old Oct 3, 2008 | 11:04 AM
Czerkas's Avatar
there are preventive maintenance tips in your manual I believe. Just look at what it tells you the dealer "will do when you take it in" at 100K and see what needs work ..
Old Oct 3, 2008 | 02:16 PM
Professor's Avatar
131k, new alt, new starter, new rotors, new rear calibers, new struts twice in the 2 years i owned it and now iam getting the roof reskinned...... hail damage.
Forgot to mention new resonator and muffler and Flex pipe, Massive expensive flex pipe, if you need one, find a shop to cut out the old and weld in the new, i did that and saver $650
Old Oct 3, 2008 | 02:48 PM
NmexMAX's Avatar
dot dot dot ...
110k here, nothing except tires.
Old Oct 3, 2008 | 03:12 PM
Scottwax's Avatar
That's Mr. Detail to you
137,600 here. Put 23,700 miles on my car in less than 11 months!
Replaced a thermostat, bank 1 rear O2 sensor, radiator and bank 1 camshaft position sensor. I had a wheel bearing go out but that appeared to be a reassmbly problem (lock nut had backed off) rather than a reliability issue with car. Changed front brake pads due to a grinding noise the pads already on the car were making. Other than that, just regular oil and ATF changes.
Old Oct 3, 2008 | 03:58 PM
NmexMAX's Avatar
dot dot dot ...
I consider brakes to be part of maintenance, just like oil, tires, etc.
KabirUTA13
19
Oct 17, 2015 02:15 AM
JoshG
51
Sep 21, 2015 10:41 PM
Socalstillen
Sep 20, 2015 11:46 PM
hntwhttail
Sep 12, 2015 03:43 PM
sdotcarter
Sep 2, 2015 09:53 PM
