Running lamps, interior lights don't work
More trouble from the 2K2 HIDs. Just helped Myktek install his and they work fine (at least they did when he left
) We had to take my lights out to figure out the wiring when we couldn't get his to work. I reconnected everything when we were done, but now none of the side markers work, the running lamps don't work, and when the headlights are on, the interior lights on the dash don't work. The interior lights also don't fade when you have the headlights on. The dome and step lights work fine. Any ideas what to do? Only change is we installed PIAA Xtreme white H3s in my fog lights. The grounds in the foglight assembly were kind of tricky, maybe we didn't get them in right?
oh shiet. . .damn, sorree tan, u should have honked, i would have stayed to help u. . .damn, LMK, i'll come help u fix them. Mine are working fine. . .and damn, getting rid of that orange makes it look good! ! !. . .will post pics soon...
Oh yeah, we didn't check to see if your headlights are aligned correctly with the wall. See if you get flashed by another driver for "high-beaming" them.
Originally posted by BigDogJonx
For sure tanmann, you got the fuse for the running/interior dash lights out.
You must have by accidently shorted it out during the install.
Check the fuse inside and see
Dixit
Dixit
Thanks for the information.
Originally posted by Tanmann9
Any idea which fuse it is? I'll check, but if they aren't labelled..
Dixit
yeah...
I hope you disconnected neg battery while doing the install. I mean you can do without, but you have to be more careful. one of the most obvious things people do it cut all the wires at once. zapppp... they will short. (in theory, no power would be on the lights tho).
It does sound like you have something seriously crossed.
Problem solved
Hey hey,
Everything is back to normal. It was a broken fuse that caused the problem. The fuse was in the engine compartment and was labelled TAIL LAMP. Strange, since the taillights worked fine (I think
though I can't remember if I checked). Replaced the fuse and everything works great now. Thanks for the help, BigDogJonx, you're a great resource to Maxima owners!
TimW: I always unplug the negative terminal on the battery before doing work on the car. It sucks having to reprogram the presets on my stereo though. Ehehe
though I can't remember if I checked). Replaced the fuse and everything works great now. Thanks for the help, BigDogJonx, you're a great resource to Maxima owners!TimW: I always unplug the negative terminal on the battery before doing work on the car. It sucks having to reprogram the presets on my stereo though. Ehehe
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
MikesChevelle
Aug 6, 2015 11:36 AM
