Car shakes in drive
Old Oct 8, 2008 | 06:37 PM
Bjs470's Avatar
Car shakes in drive
Ok, so here are some facts...
Update: Now when putting the car in drive the revs drops down til it dies.
EDIT: PROBLEM FIXED...I'M DUMB AND GLAD I DOUBLE CHECKED...SEE BOTTOM POST
Old Oct 8, 2008 | 07:01 PM
Max_5gen's Avatar
Friday I got the timing advance done on my 01 Gle, and i had half a tank of 89 octane and then filled up to 93 octane right before I got this done. After they did it, everything has been fine and Sunday I filled up full with 93 octane when the car was a little below a half tank. I then drove 300 miles back to school and the car was fine the whole time. Tonight, when I turn the car on it feels like it wants to die and the exhaust note is changing in tone. When I put the car in drive and press the brake while stopped, the car shakes back and forth and is very noticeable. The acceleration and rpms are fine especially when driving, but when I am stopped, the shaking and constant change in exhaust note is worrying me. Sorry If this is a double post, but this is kinda urgent since I'm far from home and there's not a great deal of repair places.
Try to check your coils by disconnecting 1 at a time. If one is not working disconnecting it won't make the engine run worse.
Old Oct 8, 2008 | 09:28 PM
Bjs470's Avatar
Ok, thanks for the suggestion but I really don't have any tools here at school but I'll maybe get an oil change early and have em do something
Old Oct 8, 2008 | 09:49 PM
Max_5gen's Avatar
You don't need any tools for that, only your hands. All coils connectors are on the top of the engine. OTOH you were probably expecting to hear some snake oil recommendation which doesn't involve any thinking on your account. In this case I can't be of any help and may be you will be better off to leave this to professionals.
Old Oct 8, 2008 | 11:10 PM
Bjs470's Avatar
Ok, yea I guess I feel kinda dumb now...I was just wondering if anyone had experienced it or knows what causes something like this...I do appreciate you responding and offering your advice. If the problem continues I may very well have to take it in because I am not as mechanically knowledgeable with Nissans as I would like to be.
Old Oct 8, 2008 | 11:37 PM
dewd's Avatar
is your engine jumping/ruff or is it steady in your engine bay with no shaking?
Old Oct 9, 2008 | 10:44 AM
Bjs470's Avatar
It didn't really feel like it, but it also kinda felt like the car was gonna die when I started it. But last night I didn't notice the engine shaking much, just the shaking back and forth, but It could have been the engine...
Old Oct 9, 2008 | 12:24 PM
Nelsito65's Avatar
It sure sounds as if a coil pack is going bad. My car was doing that randomly until I got the code read at Autozone and it pinpointed coil #2 as the cause.
Old Oct 9, 2008 | 12:49 PM
Bjs470's Avatar
Well your the second person to suggest that so I'm going to look into that later today. Thanks for the help.
Old Oct 9, 2008 | 02:39 PM
Bjs470's Avatar
Alright now I'm wondering if my coils are really going bad, should I be getting a check engine light soon?
Old Oct 9, 2008 | 03:46 PM
Bjs470's Avatar
Update: Now when starting the car, and putting it in Drive, the revs drops down til it dies. Any Ideas? I should be able to make it to a shop I hope
Old Oct 9, 2008 | 04:09 PM
Grand_hustle17's Avatar
does the engine shake, leave ur car at idle pop ur hood and play with each coil wrire, mines had a short at coil 1, i fixed it myself, n im the worste mechanic in the world
Old Oct 9, 2008 | 04:39 PM
Bjs470's Avatar
Problem is it won't idle, cuz it dies after 5-10 seconds after start up
Old Oct 9, 2008 | 04:53 PM
playboi21617's Avatar
maybe you have dirty injector or maybe try changing your spark plugs.
i use to have a 92 maxima and when i put in drive it would shake and the mechanic told me that one of my injector werent working
Old Oct 9, 2008 | 05:47 PM
Max_5gen's Avatar
Well, you could open throttle a little by hand from the engine bay to keep it up.
Old Oct 9, 2008 | 05:52 PM
Bjs470's Avatar
Oh yea I never thought of that...duh
Old Oct 9, 2008 | 06:57 PM
Kevin319's Avatar
hey I had the SAME problem after coming back from Pepboys, there suppose to fix problems not cause. yes everything works perfectly in the car but the shaking is VERY noticeable when your idleing or not moving it feels like ur car is gonna die. for some reason, if you rev your car to around 4-5 rpm, the shaking stops. I don't know why but this stops the shaking but im going to ask pepboys and complain.
Old Oct 9, 2008 | 07:17 PM
Bjs470's Avatar
Interesting...This sounds similar but now the darn thing dies after a few secs
Old Oct 9, 2008 | 09:47 PM
Bjs470's Avatar
bump
Old Oct 10, 2008 | 06:04 AM
Max_5gen's Avatar
To get help here you have to provide additional information, otherwise you can do it just as well yourself. You must know that all the engine needs is fuel and spark, so all is left to figure out details.
Old Oct 10, 2008 | 07:54 AM
Niccos89's Avatar
Checked tranny fluid? If theyre fine, vacuum leak...maybe?
I dunno, theres my two cents
Old Oct 10, 2008 | 12:09 PM
Wildcat_Max's Avatar
If its auto, do check your motor mounts. I had similar problems with my 2k max, the engine use to really shake in drive and in neutral.
Old Oct 10, 2008 | 12:30 PM
Bjs470's Avatar
OK I FEEL REALLY DUMB NOW...I CHECKED THE ENGINE AGAIN TODAY AND NOTICED MY INTAKE WAS LOOSELY CONNECTED AND THE CLAMP SLID OFF BY THE MAF. I REATTACHED IT AND THE CAR WAS FINE...THANKS FOR THE HELP EVERYONE...GLAD I DOUBLE CHECKED
Old Oct 10, 2008 | 01:49 PM
Nelsito65's Avatar
Glad to know you found the cause and appreciate you posted back.
Old Oct 11, 2008 | 08:02 AM
maxfever1987's Avatar
luckily for u it was that simple, in my 2000 se i had to replace all the coils
Old Oct 11, 2008 | 10:40 AM
Bjs470's Avatar
Yea I am thankful seeing as my max has a little over 93k and is an 01
Old Oct 16, 2008 | 09:09 PM
Kevin319's Avatar
Hey, did you have a hole on your front passenger side motor mount? Brought my car to Nissan and they discovered a hole in my engine mount. What did you do with yours? Does it cause shakes in drive as well?
Old Oct 16, 2008 | 09:39 PM
Bjs470's Avatar
I actually got it figured out...I looked more carefully during the day, cuz the problem started at night, and it was too dark. The clamp holding the intake together by the MAF was loose and the intake wasn't even connected to the engine.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
yat70458
Aug 3, 2015 01:16 PM
