Help. Missing connection
Old Oct 12, 2008 | 10:10 AM
black2kse's Avatar
Can anyone tell me what this wire connects to?
Old Oct 12, 2008 | 10:14 AM
Professor's Avatar
what wire ? i dont see anything.
Old Oct 12, 2008 | 10:21 AM
black2kse's Avatar
Old Oct 12, 2008 | 02:17 PM
pmohr's Avatar
No more Maximas...
Originally Posted by black2kse
Have you tried following it back to what it came from? It looks like a component side connector, not harness side.
Old Oct 12, 2008 | 02:29 PM
Feldman's Avatar
any cel's?
Old Oct 12, 2008 | 03:20 PM
black2kse's Avatar
It comes off of the wire loom shown in the picture above the connector.
Old Oct 12, 2008 | 03:22 PM
black2kse's Avatar
what is cel
pmohr's Avatar
No more Maximas...
Could be for ABS, or the VSS. What wire colors go into the connector?
Old Oct 12, 2008 | 04:21 PM
pmohr's Avatar
No more Maximas...
what is cel
Check Engine Light...
Old Oct 12, 2008 | 06:17 PM
black2kse's Avatar
No CEL. The wires leading to the connector are black and red.
Old Oct 12, 2008 | 06:49 PM
pmohr's Avatar
No more Maximas...
Do you have traction control? Does your speedo work?
The VSS connector looks similar, and the two wires are red and black. If you have traction control, the ECU takes speed data from the VSS, otherwise it gets its info from the ABS system. According to what I can tell from the FSM, anyway.
Old Oct 12, 2008 | 08:25 PM
black2kse's Avatar
I do not have traction control. The car is still on jack stands. The wire does not reach the Speed sensor.
Old Oct 12, 2008 | 08:37 PM
pmohr's Avatar
No more Maximas...
Well, does your speedo work?
The VSS has a fairly long harness that comes out to around the trans mount to connect to the engine control harness.
Regardless, from the look and pinout you've given (assuming that's even correct) it's the connector for the VSS. Without any more details or help from you, figure it out by yourself.
jmlee44
Oct 2, 2022 02:13 PM
zmcneely13
Sep 26, 2015 02:26 PM
rbaker100
Sep 25, 2015 07:52 PM
