Manual temp gauge?
Old Oct 26, 2008 | 02:59 PM
PhalC1's Avatar
Manual temp gauge?
How do I install it? Do I have to tap in to the radiator or somewhere else?
Old Oct 26, 2008 | 04:05 PM
VQP0WER's Avatar
Tap it off the coolant temp sensor located on the left side of the motor. Your car already has a engine/coolant temp gauge, why do you want another one?
Old Oct 26, 2008 | 06:23 PM
Scottwax's Avatar
That's Mr. Detail to you
Probably because ours are weighted so minor variations don't make the needle move. Car manufacturers do that on purpose so people don't panic when the needle moves once the car reaches normal operating temperature. However, if you drag race, knowing the exact coolant temperture can be very helpful.
Old Oct 27, 2008 | 12:31 AM
PhalC1's Avatar
That's pretty much it. I read someone saying that their stock gauge reads normal and the aftermarket one with actual temperatures can differentiate ~40 degrees
Old Oct 27, 2008 | 03:39 PM
Scottwax's Avatar
It isn't that the factory gauges are that inaccurate but if the temperature swing is 20 degrees from normal when in heavy stop and go traffic on a hot day, the needle won't move to reflect that. An aftermarket gauge will show the actual temperature changes.
Old Oct 28, 2008 | 10:50 AM
PhalC1's Avatar
And to add to that I had radiator problems so now I'm sort of paranoid lol
Old Oct 28, 2008 | 03:02 PM
RA030726's Avatar
I'm nutty for Nissans
You need a place to tap into. I fabbed up a water temp gauge adapter and cut the upper radiator hose. You may find one on ebay.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
