Inner Tie Rod Spun? Problem?
Old Oct 27, 2008 | 08:37 AM
MaxManOhio's Avatar
While loosening up the outer tie rod lock nut, the inner tie rod spun, maybe 3/4 of turn. So in essence, it was broke loose. I put the outer tie rod end, but am now wondering if I need to tighten the inner tie rod? I thought it had some type of locking mechanism on it so I did not worry about it, but I have not pulled the boot off and now I am wondering. Any thoughts? Thanks guys
Old Oct 27, 2008 | 09:50 AM
jd885's Avatar
Well if it spun 3/4 of a turn i would spin it back, other than that the car will be misaligned if you dont
Old Oct 27, 2008 | 08:31 PM
xnyc's Avatar
the inner tie rod is a ball/socket joint. it will turn. dont worry about it
^fail. if it was loose, misalignment would be the least of his concerns.
Old Oct 28, 2008 | 07:10 AM
MaxManOhio's Avatar
Thanks for the responses. The inner tie rod is solid it just got loosened in fighting the lock nut on the outer tie rod end. It is back together and does not move a bit. I figured if it is locked at the outer tie rod end with the lock nut, it could not move. But since I have never messed with suspension work, I wanted to be sure.
James92SE
142
Jan 2, 2024 09:23 AM
londonflu
Sep 19, 2015 02:33 PM
Bonka
Sep 14, 2015 11:18 PM
MikesChevelle
Sep 7, 2015 09:11 AM
