Rev Limiter on 2002 6 speed is 7000 RPM
Old Nov 12, 2001 | 10:39 PM
Paul6speed's Avatar
A little bird told me this. The tach redline is 6500, but mine goes to 7000. Steve... is your's the same?
Old Nov 12, 2001 | 10:42 PM
Wizeguy's Avatar
Re: Rev Limiter on 2002 6 speed is 7000 RPM
Ah... It sounds like your enjoying your car.
Now about those track times?
Old Nov 13, 2001 | 04:40 AM
Max_Gator's Avatar
Re: Re: Rev Limiter on 2002 6 speed is 7000 RPM
(chanting) DYNO .. . DYNO . . . DYNO . . . DYNO
Old Nov 13, 2001 | 04:44 AM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
i think mine is around the same, whenever my little bird was telling me a was so nervous i didn't get an exact number, i was too busy swearing at him.
Old Nov 13, 2001 | 04:49 AM
Mr. Green's Avatar
I've hit my rev limiter quite a few times and I thought it was around 6800-6900 rpm on my 2k 5-spd. If its 7000 rpm on the 6-spd 2k2, then that kicks a**. The 2k2 keeps sounding better & better.
Paul have you tried to get a 1/4 time on your car yet?
Tim
Old Nov 13, 2001 | 04:59 AM
UMD_MaxSE's Avatar
Got Bent?
Old Nov 13, 2001 | 05:43 AM
soundmike's Avatar
Very sound, Mike
Re: Re: Re: Rev Limiter on 2002 6 speed is 7000 RPM
Ok, i know i have an auto but hey at least it'll give y'all some ideas. I'm scheduled for my dyno run this P.M.
I'll try to get the stats up tonight or early tomorrow
Old Nov 13, 2001 | 05:44 AM
i•maxx's Avatar
Wow!…
takin' it to the max, already now!!
Old Nov 13, 2001 | 05:46 AM
Max_Gator's Avatar
Re: Re: Re: Re: Rev Limiter on 2002 6 speed is 7000 RPM
Old Nov 13, 2001 | 05:52 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Out playing last night, eh? hehe, you shoulda called me
Old Nov 13, 2001 | 07:23 AM
bigbadboss101's Avatar
Is that a bad thing? I guess for family people one would want the limiter before redline but for crazy folks like us it can be after readline but before 10000 rpm?
Old Nov 13, 2001 | 08:50 AM
PhatGuy
That is awesome to say the least! As yo said once you get a CAI on there it is going to sound wicked!
Old Nov 13, 2001 | 11:29 AM
Nismo87SE's Avatar
I bet fuel cut is really 6500-6600rpm like the VQ30DEs are. Your tach is just off, however a shift light would give you the real deal though .
Old Nov 13, 2001 | 11:35 AM
UMD_MaxSE's Avatar
Got Bent?
Paul,
want to meet up and hook your car up to my scan tool? That will tell us what redline really is
Old Nov 13, 2001 | 11:38 AM
PhatGuy
I highly doubt his tach is off by 400-500rpm. Tachs are very accurate. How is a shift light going to tell where the cut off is since the it is tied into the tach anyways?
Old Nov 13, 2001 | 12:00 PM
Paul6speed's Avatar
Yeah... let's do it really soon. I doubt my tach is off that much.
Originally posted by UMD_MaxSE
Paul,
Old Nov 13, 2001 | 12:20 PM
Paul6speed's Avatar
Yep. I did run it this past Friday. 14.7 @ 97. I think I can improve upon that though. Since I haven't driven a stick in a long time, I couldn't get my launch down. My 60 ft times were awful. 2.3-2.6. I was doing better with my older automagic in that regard. Also, I was shifting too early. Coming home from the track I discovered that my fuel cutoff is much higher than the advertised 6500. Also... I had more gas than I wanted (1/2 tank). I went to the track at the last minute. Usually I plan it a week in advance and show up with my fuel light on. LOL. My 280 lb body doesn't help either, but there's no quick solution for that. That will be a long term project. I plan to go back soon and shift higher. I also plan to slip the clutch a little. I couldn't bring myself to do it at this last outing.
I have no doubt I can achieve 14.5. If I can improve my 60 ft times and shift higher, low 14's are possible.
Old Nov 13, 2001 | 12:53 PM
HulaMAX's Avatar
Whoa!!! Sounds like u'r having fun already!
Old Nov 13, 2001 | 03:12 PM
sweet man, you gonna go to Island dragway on December 2nd.
Old Nov 13, 2001 | 03:39 PM
AznWontonboy's Avatar
Sweet.. but i think you should only shift at 7000rpms for the first two gears.. after that, redline.. i wouldnt want to waste time when the power starts going downhill fast. remember, max hp at 5900rpms
Old Nov 13, 2001 | 03:58 PM
soundmike's Avatar
Very sound, Mike
Hey if you're interested the 2k2 Max dyno (auto) is up
click here
Old Nov 13, 2001 | 04:19 PM
Originally posted by yo_its_ok
as much as power is a factor so is RPMS~!
higher the RPM before shift the better potential to get into your "fat" part of the powerband, and have better acceleration times.
However you must experiment with your shifting and know what your "fat" part of the powerband is to have Maxximum Acceleration..
YUP! 7000rpm family car
Old Nov 13, 2001 | 05:15 PM
TL-S
We have a flatter power band or not
Old Nov 13, 2001 | 05:20 PM
RussMaxManiac
Actually they are not very accurate. They are way off. Trust me, on most Nissan's they are off. 2 reasons why shift lights are bought, 1st so you don't have to look at the tach to shift, and for accuracy.
The SE-Rs are known for this, and the Maximas as well for 3rd gens, I am sure 4th and 5th as well.
Old Nov 13, 2001 | 05:38 PM
Y2KMaxGXE-R's Avatar
Paul, I weigh 140 and can run your car for you LOLOL. How many miles on your car? Isn't that a little too early to be taking it to the track? Go 14.3!
Old Nov 13, 2001 | 05:48 PM
emax02's Avatar
Hmm, it look's like shifting at 6500 RPM in each gear would be ideal. If you look at the dyno chart {above} the power peaks at about 5400 RPM and holds strong until 6000, then it dips a little bit and bounces back up tp peak power at 6500 rpm. This is good, I would love to see a chart with a intake and a Y-Pipe, I bet the peak power would easaly go all the way up to redline{what ever RPM that is?}. The 2K2's power band does not drop off like a 4th gens..
Old Nov 13, 2001 | 07:51 PM
Paul6speed's Avatar
I remember my previous automagic having a different dyno plot than the 5 speeds. Same basic shape, but all at lower levels. I wonder if the same applies to the 3.5 VQ. We shall see. Also, I'll see if shifing at 7000 RPM will affect my ET. If running it to 7K doesn't lower my ET, than it will become obvious about the shift points.
Old Nov 13, 2001 | 09:05 PM
All I know is that A TL S beat me in a "more than a 1/4 mi race cause my traps are at 90-91 mph and I was at 96 when all I see TL-S gauges right next to me...LoL...I had him off the launch... had him til 50mph bottom of 2nd gear... and from 60 to 70 he caught up and passed me...by 80 I was inching back up... and at 96 I got my door to his door...
j00 tell me...WTF ?
Maybe one of his gears are better?
Old Nov 13, 2001 | 10:01 PM
his top of 2nd and his 3rd gear got me ... his 4th gear sux and thats when I was catching up... by 100 I should be past him...
Take him out
Old Nov 14, 2001 | 12:26 AM
Mr. Green's Avatar
Paul now that you know you're baseline performance, what do you think it will take to break into the 13's? What mods and tricks will you employ?
I'm finding you're day to day reporting on the life and times of the 6-Speed very informative.
bryants95max
Oct 2, 2015 12:52 PM
Djsmaxima
Sep 14, 2015 11:58 PM
Maxxx10
Sep 13, 2015 03:16 PM
jcvgn
Sep 10, 2015 08:03 PM
