Loud pinging and knocking coming from the engine?
Old Nov 13, 2001 | 11:19 AM
edadams's Avatar
Has anyone had a problem with the engine pinging on their max. I have a 2k se auto with 26000 miles. The car will knock and ping under 1/2 throttle or above sometimes. I only use 93 octane fuel and I do use mobil 1 oil. The car does have a version of the oscai installed. If anyone has any suggestions please repond.
Old Nov 13, 2001 | 11:27 AM
Jeff92se's Avatar
I'm needing a caw
Your car should NOT be acting that way. It's way too new. Sounds like a detontation sensor problem or an ECU program problem. It could also be one of the sensors signaling the ecu the wrong timing information(ie... crank angle sensor). I assume your car is under warranty to please take it back asap. If the knocking is as loud as you describe, you stand a good chance at ruining your engine. Please drive it very easy for now and get it fixed asap!
Old Nov 13, 2001 | 11:31 AM
UMD_MaxSE's Avatar
Got Bent?
a fwe people have had bad ignition coils that caused the problem. I suggest you take it to the dealer and have it looked at.
Old Nov 13, 2001 | 12:18 PM
BigDogJonx's Avatar
Hey Nauman, this reminds, me, my Knocking that I was talking to you about in Reverse, I kinda hear it now in forward. So last night I got out the car while it was knocking to find out where the hell it is coming from. Guess what, at idle rpms, the UDP seems to be shaking. I dont know if the bolt is loose on it or what. But at high rpms, the UDP seems to be balanced, like it does not shake.
I am going to have to figure this one out, might have to go to my friends shop and possibly tighten the bastard back up with a Impact wrench.
Dixit
PS, by the way, I just bought a Electrical Impact wrench, we can do the spring install on your car in a snap now. Lets be indy style and try to get it done in say............. 1.5hrs. HAHAHA
Old Nov 13, 2001 | 12:29 PM
UMD_MaxSE's Avatar
Got Bent?
Dixit
hmmmm.... you may also want to check the idler pulley... that may also be the culprit.
So you go the impact wrench huh... cool... once I get the car back and get the struts, we'll do it
Old Nov 13, 2001 | 12:34 PM
punkdork's Avatar
Oooh tools! I'm jealous
Old Nov 13, 2001 | 01:30 PM
Colonel's Avatar
Old Fuddy Duddy
Re: Loud pinging and knocking coming from the engine?
Don't forget to put in the stock air assembly because you know the dealer is going to have a fit seeing it there and IMMEDIATELY state that is your problem.
Hondarydr
Dec 30, 2024 06:15 PM
maxinout93
Oct 27, 2015 01:29 PM
maxinout93
Aug 20, 2015 02:17 AM
follyburr
Aug 7, 2015 09:50 PM
