WTF, left side head light is completly dead along wiht the auto matic lights
Old Dec 2, 2008 | 05:19 PM
imported_D_Roc's Avatar
ok i dindt even touch the headlamps but all sudden the left die head light both high and low beam is gone along with the automatic lights (when its dark lights come up), it worked fine till this morning. I checked bot right and left side relays, fuses and the bulbs, but i can't find a fuse tot he auto lights so where is it. any idea what went wrong
thanks
D
Old Dec 2, 2008 | 05:30 PM
jasonmax's Avatar
thanks
D
don't forget there are some fuses under the hood.
Old Dec 2, 2008 | 05:31 PM
VQP0WER's Avatar
You sure you didn't screw it up wiring your remote? The headlamps are tied into the SECU at pin 49.
Fuses should be # 68 & 69
Old Dec 2, 2008 | 05:37 PM
yea i checked the fueses under the hood the 2 15A, no i dindt even touch the harness where pin49 is and the starter is not hooked yet yer wired
Old Dec 2, 2008 | 05:42 PM
ummm..... i'm a dumbass ignore it i removed one of the harnesses on the SECU and forgot to put ti back,
but question with that harness off still the remote worked, (lock unlock) so is that mean that the power lock wire is not in that harness?
thanks
D
Old Dec 2, 2008 | 05:51 PM
nsnrider's Avatar
if you recently did some electrical work, go back and recheck all your connections. Recheck all fuses especially those listed as "electrical parts". GL
vingodine
45
May 21, 2016 12:46 PM
Balkins
Feb 1, 2016 12:45 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Flores94
Aug 11, 2015 12:53 PM
kjm900r
Aug 5, 2015 07:14 AM
