Horrible problem with the wheel bearing!! PLEASE HELP
Old Dec 14, 2008 | 11:06 AM
shaunkey1's Avatar
Hey guys
I have a 2002 MAXIMA and it has given me major problems with the passenger side wheel bearing. in the last year and a half, I replaced the bearing 3 TIMES!!!! There has to be a problem with something else, right? How could a bearing broke so many times?? Please give me any recommendations that you have. Also, how much will it cost to get the bearing fixed at a dealer?
Thanks for your help!
Old Dec 14, 2008 | 11:10 AM
Professor's Avatar
Ide say its either been installed cockeyed or it was over tightened to many times, ide suggest a new knuckle.
Old Dec 14, 2008 | 12:36 PM
P. Samson's Avatar
This comes up quite often it seems. This is either an assembly problem, or it's a part(s) issue. If the steering knuckle (the bearing bore), certain critical areas of the hub and/or the outer axle shaft are damaged or worn, and then if these parts are reused, then the new bearing can fail again very soon after. And I'll say it again.......the torquing of the bearing lock nut to 188-245 ft/lbs is damn important as well. (It's pretty difficult to "overtighten" it)
Old Dec 14, 2008 | 01:05 PM
louie2k3's Avatar
get a wheel hub assembly!! i had the same problem!!!!
Old Dec 14, 2008 | 03:44 PM
Professor's Avatar
Old Dec 14, 2008 | 04:56 PM
4DRZ's Avatar
A new hub will fix you right up! After having to replace the bearing so many times, to me, I would suspect that the real damage was caused by the bearing , when gone bad, left in there too long, and chewing up the hub. Checkers, autozone, and discount auto have them for our cars, and they are about $65.00. (from nissan the assemby is about $160.00)
Originally Posted by Professor
Old Dec 15, 2008 | 06:48 PM
tbergma1's Avatar
Yep, I put on a new hub, no probs
I got mine for $135 from nissan. I think the guy gave me a discount though.
Old Dec 15, 2008 | 06:58 PM
blkAEmax82's Avatar
Glory Glory Man United
Definitely should of change the hubs when you did the bearings.
Old Dec 15, 2008 | 08:27 PM
tbergma1's Avatar
You have the same wheels i have, amazing how brake dust can make them look totally different.
Old Dec 15, 2008 | 08:45 PM
hi-tek22's Avatar
i think Dave B wants to charge me 154 for the wheel hub and 54 bucks for the bearing
OUCH!......
Here is my problem:.....i get this grinding noise when i make right turns while still on the gas
http://forums.maxima.org/5th-generat...front-end.html
matts95max
Apr 23, 2025 10:44 AM
boomerbrian
Oct 31, 2018 10:25 AM
BkGreen97
Apr 2, 2016 05:47 AM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
