Heads... How much torque?
Old Jan 3, 2009 | 04:04 PM
Double0GLE's Avatar
How much torque do you use for the bolts on the heads?
Old Jan 3, 2009 | 04:20 PM
Feldman's Avatar
http://forums.maxima.org/general-max...niti-fsms.html
quick answer is 72 ft-lb but they need to be tightened in a specific order which is in the FSM
Old Jan 3, 2009 | 10:37 PM
rroderiques77's Avatar
Demodded and Forgotten
The order should be from inside out in a circular pattern
Old Jan 3, 2009 | 11:16 PM
Feldman's Avatar
the FSM says to criss-cross from the inside out if that makes sense.
7 1 3 5
6 4 2 8
Old Jan 4, 2009 | 07:05 AM
KRRZ350's Avatar
WOW, you're definitly going to want to follow a few steps in the FSM, and they also require angular tightening.
Old Jan 4, 2009 | 01:09 PM
Double0GLE's Avatar
Thanks everyone
Old Jan 4, 2009 | 05:15 PM
nismology's Avatar
You removed the heads without looking at any kind of service manual?
Old Jan 5, 2009 | 01:31 AM
Double0GLE's Avatar
Negative. Irishj44 (I think) had a write up on a ground kit he did himself and it requires to use one of the bolts for the head. I want to remove it now and I don't remember what the torque spec was. When I was doing it, I was working at the Nissan dealership and I walked over to a tech and asked him while I borrowed his tool.
Old Jan 5, 2009 | 07:25 AM
pmohr's Avatar
No more Maximas...
Good luck finding a grounding kit that uses a head bolt.
Can you take a pic of what bolt you're talking about? You're confusing everyone here by implying that it's a head bolt.
More than likely it's just a regular 10 or 12mm head bolt. Tight is fine.
Mar 12, 2020 12:06 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
The Wizard
24
Oct 1, 2015 08:47 PM
dcam0326
Sep 18, 2015 04:52 PM
