Heated Seats Not Working
Old Jan 17, 2009 | 03:08 PM
STILLENGLE's Avatar
So, My heated seats stopped working Every now and then it will turn on but it wont get warm, but then sometimes it wont turn on.
anyone know what's up.
Old Jan 17, 2009 | 03:15 PM
bigpopaj369's Avatar
you prolly have to replace the switch i have had the same issue and that was the problem here and there it worked so i went on ebay and found the same part it was really cheap, best of luck.
Old Jan 22, 2009 | 12:06 PM
Ramius83's Avatar
Could be switch, could be fuse, could be a bad heater element. Best thing to do is to unbolt the seat, push it backwards so you can locate the wire harness for the heater. Then back-probe the wires with a test light and see if you have power. If you do, then the heater is bad. If not, then it is a fuse, switch, or wiring problem....
dr3am
25
Oct 22, 2015 08:53 PM
rtirbany
Sep 8, 2015 11:46 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
98nismomax
Aug 13, 2015 12:15 PM
