How to tell if the slow 2-3 shifts are from tranny? or valve body
Old Jan 25, 2009 | 07:32 PM
MidN1te's Avatar
Thats pretty much my question. I've read around that when trying to race with an auto its a slooow shift from 1-2, but when i drive normally i have a 2-3 slow shift and after it shifts it hits the 3rd gear just a tad harder and when into 4 its quick and smooth.
my old 2002 maxima didnt do this but just had the slow 1-2 shift when i floored it.
how can i tell if its the tranny or the valve body? and will the valve body mod fix this?
Thanks!!
Old Jan 25, 2009 | 08:30 PM
Scottwax's Avatar
That's Mr. Detail to you
If the tranny slips on the 2-3 upshift when cold but perfect once fully warmed up, odds are it is the valve body. A shift kit (which modifies the valve body) should fix that and make all shifts firmer and faster.
Old Jan 25, 2009 | 08:46 PM
Stormzusmc's Avatar
dont mean to steal the thread but, does anyone have any recommendations on good shift kits for the 02 03 autos?
Old Jan 25, 2009 | 09:33 PM
hi-tek22's Avatar
where would you get a shift kit from?
Old Jan 26, 2009 | 08:49 AM
Scottwax's Avatar
http://www.jdsperformance.com/index....=item&inmake=0
RE4FO4B Kit: RE4FO4B PSK Automatic Shifts
4 Speed Front Drive No Throttle Cable
Fits: NISSAN Maxima-Altima 2000-04, Quest 2003-04, MERCURY Villager 4F2OE 2003-04, Infinity i30 2000-04.
Old Jan 26, 2009 | 09:33 AM
Stormzusmc's Avatar
thanks, yeah i saw that one....wish they had more info...i try to refrain from websites buying stuff off of websites that look like they are built by a 6 y/o...anyway thanks again for the link and info
Old Jan 26, 2009 | 12:46 PM
Scottwax's Avatar
Not everyone is that good at building websites.
Old Jan 26, 2009 | 02:11 PM
timbit's Avatar
I just purchased my '02 (private sale) and have the same problem. I have spent the last 3 days trying to figure out the best fix. Had the flush done at the dealer last week, previous owner was on top of maint. and I read all his records. Fluid looked good, not burnt at all when changed. Mr Transmission wanted to take it apart for 700.00 plus what ever they find. Every other shift is perfect, just this slow 2-3. I drove it hard on the test drive and of course it was fine, just under normal driving conditions, it drives me crazy. The car is fantastic in every other way and has 135,000 kilometers on it. I need help!
Old Jan 26, 2009 | 05:10 PM
Scottwax's Avatar
When the car is fully warmed up, how does it shift? Down here in the Dallas area, it takes about 2-3 miles of driving in 30 degree weather (I guess that is -1 C) for the transmission to warm up enough to tighten up the 2-3 shift. Up in your neck of the woods, it will probably take longer to warm up due to the colder temperatures.
FWIW, my car had 113,897 miles on it when I bought it and I noticed the cold weather 2-3 slow or slightly slipping upshift. I now have 144,150 (or so) miles on my car and despite doing nothing, the problem isn't getting worse. I've got 60,000 miles more on my transmission that you do on yours and it still shifts great once it fully warms up. Whether or not the slip will reduce longevity of the clutch packs I guess depends on what Nissan considers to be the normal lifespan on the transmission. Typically, an automatic transmission with regular fluid changes will last around 200,000 miles before requiring a rebuild.
My solution right now is to slightly lift off the gas right before the 2-3 upshift to prevent any slip. Long term solutions are the Transgo Shift Kit or a new vavle body, which costs about 10x the price of the shift kit with about the same installation cost.
Old Jan 26, 2009 | 10:07 PM
Stormzusmc's Avatar
spose youre right lol thanks again tho
Old Jan 26, 2009 | 10:08 PM
Stormzusmc's Avatar
and that would run someone? i guess i could ask a shop but lol
Old Jan 26, 2009 | 10:30 PM
Scottwax's Avatar
The estimated time to install the shift kit is 3 hours plus you will need several quarts of ATF. I'd call around for a transmission shop that has experience installing shift kits. Expect them to charge $75-100 an hour labor.
Still be cheaper than $1200 for just the vavle body itself from Nissan and you'd get quicker, firmer shifts.
Old Feb 6, 2009 | 05:56 AM
MidN1te's Avatar
so this is an actual shift kit? not changing the valve body? so if i send the valve body to level 10 or something and have them do their thing on it... isnt that the same? or no?
Old Feb 6, 2009 | 07:41 AM
Scottwax's Avatar
Shift kits modify the valve body.
Old Feb 6, 2009 | 04:17 PM
MidN1te's Avatar
Thankyou.... hahahah..
Mar 12, 2020 12:06 AM
97_GXE
20
Sep 17, 2015 08:12 PM
tardrex
Sep 11, 2015 07:35 PM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
