Intermittent knocking / vibration
Old Jan 25, 2009 | 08:16 PM
zero2sixtyZ's Avatar
You embarrass me.
I'll keep this short:
- Happened so far 3 times, fairly severe each time.
- Happens when the car has been on the highway or driving for a while
- Progressively steering wheel gets a bit more play and starts "tugging" towards the right
- When in full force, there is a knocking noise from front passenger side wheel well, and has gotten to the point where the wheel would pull from my hands.
- Recently had new ball joints, and passenger side axle replaced.
- Taken to two mechanics, and could not reproduce problem easily nor find anything obvious wrong under car.
- HALP!
Old Jan 26, 2009 | 07:04 AM
perkman87's Avatar
Make sure the Wheel is not shaking from side to side. If it is tighten the Wheel bearing bolt to the correct Specs.
Old Jan 26, 2009 | 02:42 PM
maximadudeIIs's Avatar
Sounds like wheel bearings to me. Also get an alignment done.
Old Jan 26, 2009 | 08:29 PM
You embarrass me.
Had an alignment done recently when my winter tires were installed. This issue has happened before the alignment and the winters as well, so it cancels out loose ends there and the tires/wheels.
Old Jan 28, 2009 | 09:12 AM
You embarrass me.
Starting to sound like an axle issue. Getting worse and louder. Mainly happens during left turns, starting to act upon right turns as well.
Old Jan 28, 2009 | 09:38 AM
If you had an alignment done recently, then as you say it may be an axle issue. Do they make a "click" sound on turns?
Old Feb 7, 2009 | 06:32 AM
graveyca's Avatar
Im having the same problem that you described.
Ive had an alignment done, replaced tie rod ends and lower control arms, all of this was done recently.
Ive noticed that when i take my foot of the gas that it does this
Does anyone have an idea what could be wrong
I even took it to nissan and they did jack squat
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
06maxima55
Sep 28, 2015 04:29 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
