Grille Options...
Grille Options...
http://www.andysautosport.com/nissan...e00134672.html
What you guys think of this? It's going on a white max
I also just purchased these Projectors.
http://cgi.ebay.com/ebaymotors/ws/eB...ht_6238wt_1043
The projectors are a good pick as long as YOU like how they look...the light output is not horrible as long as they are aimed properly, although the beam pattern is a bit scattered...unlike other people I speak from experience as I owned a similar set of projectors before retrofitting TSX lenses into mine.
Regarding the grille...IMO the black grille will not look very good with the chrome-housing projectors (there will be a lot of contrast). I would have gone for the black-housing projectors to accentuate the black-painted grille.
Maybe post some pics once you have everything installed and we can see how it looks
In my opinion, there are no good aftermarket grilles for 5/5.5 gen Maximas. Go OEM. You also mentioned you own a 2000 Maxima. Not sure if you're aware, but the 2000 ones have the grille molded onto the bumper. So you either have to cut it out and fabricate your own attachment, or purchase a 02-03 front fascia/bumper to install a new grille.
As for the projectors, I currently own a set. Like M1RAG3 said, they're not as bad as everyone says they are, provided they are aimed correctly. Better than stock 00-01 halogen anyways. But again, my advice is to save up and go OEM. Get a set of 5.5 gen HID D2R headlights. You can always do a projector retrofit later down the road. That's what I'm replacing my Ebay projectors with.
you should talk to torgus and have him make you a grill. http://forums.maxima.org/5th-generat...an-emblem.html
Like shogun said there really isnt any good choices for grills.
should have went with umnitzas halos. but buying the whole headlight assembly is alot easier.
its like i pointed to flash lights on the road and thats it, those two little spots.
Goodluck.
i dont like the grill...I almost purchased a set of those ebay projectors..But i changed my mind and got a set of 02-03 OEM's...Also like DaveVQ said, i was also turned off by the fact that the H3 bulb is the "main" headlight
I say find another choice of grill
where are you guys picking up these billet grilles? have one on my 2000 but it was hit in front and bent the grille i need another and cant find it anywhere!
if anyone getting rid of thiers for a 2000 please advise.
the grille is molded into the 2000-01 bumper. You can cut it out and use a Street Scene Mesh grille for a replacement.
True that the grille is molded. however this particular grill bolts directly over and very flush with the existing grill still in place. SS grille would be a last resort if in fact i cant get my hands on another billet.
You're gonna need a wiring harness and 02-03 headlight clips, call DaveB
Has anyone attempted to retrofit a 5.5 grill into a 2K bumper?? (assuming the grill has been cut out) the size of the grills look nearly identical...$hit, the headlights from a 5.5 fit......
Hello all. I have a 2002 GLE and I have been looking for a billet grille to find and can only find on for the top. Why is it that I can't find on for the bottom on a GLE. Its only the GLE model that they do not supply for. I need some help. thanks
How'd you go about doing that? The reason I ask is because that came out REALLY nice. I've seen several write-ups on how to do this, all with varying materials and directions. Yours isn't too glossy or flat, it looks like it would match KH3 perfectly.
^ It's pretty glossy, but that's the look I was going for. I used Krylon Fusion for plastic (flat black) and Duplicolor clear coat. I had to wetsand in between some of the black coats to prevent too much 'orange peel' texture and keep it smooth.
http://www.grille-tech.com/detail.ht...rch=Search+%BB
black powder coat street scene grille would look fresh
http://www.streetsceneeq.com/product_list.asp?mi=5
where to get it though?? I called and spoke with mike at sreetscene and the blackpowder coated grille is out and you can order one at summitracing
