So new headlights.. Just not fitting
Old Feb 19, 2009 | 07:06 PM
NismoSpeed's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...ht_6238wt_1052
So I purchased these, and now have gone through 2 clips to hook the bottom of the headlight. So now I gotta order more again, and really starting to wonder why these do not fit properly on my 00. I'm wondering how to get these to fit, because they seem to fit perfectly when the clips are not present, but of course they wobble and are not a tight fit. So i'm wondering from anyone, if you can help me out. I spent 300 on these and about to call it quits and sell them.
Old Feb 19, 2009 | 08:05 PM
NismoSpeed's Avatar
So we have decided to go without the clips because they are not letting the lights go in properly or all the way. Without em, yeah they are on there as good, but we found a way to hook the bottoms. So we are just gonna go that route.
Old Feb 19, 2009 | 08:09 PM
choiiiiiiiiiii's Avatar
yay.....
Old Feb 19, 2009 | 08:15 PM
GOPkiller's Avatar
Had the same problem when I bought my new halo headlights. I had to cut the bottom clips off for them to fit properly. It's still a pretty tight fit. Someone told me that many exterior OEM parts are purposely designed to not have a perfect fit, to somehow prevent car companies from suing them for infringement
Old Feb 19, 2009 | 08:25 PM
Drockb418's Avatar
go to the dealer and buy the 02 and 03 clips and then ur good to go.
Old Feb 19, 2009 | 08:26 PM
Drockb418's Avatar
but at the same time ur going to find out how much they suck
Old Feb 19, 2009 | 11:04 PM
hi-tek22's Avatar
02-03 headlight clips and u will be good to go (like previous member said)
better yet call Dave B and save a trip......
Old Feb 20, 2009 | 05:40 AM
nissandrvr98's Avatar
so hows the headlight output with the projector..got any wall shots?
Old Feb 20, 2009 | 10:09 AM
max2003tim's Avatar
I bought these recently http://www.k2motor.com/lf-max02coem.html and they are very good.
Old Feb 20, 2009 | 08:41 PM
showgun9's Avatar
Dude your link points to aftermarket fogs and the OP was discussing the installation of aftermarket headlights
Old Feb 20, 2009 | 09:44 PM
Bjs470's Avatar
yea haha
Old Feb 21, 2009 | 01:02 AM
NismoSpeed's Avatar
Output of the headlights are great, a heck of a lot better then the stock ones. I do however still need to adjust the angel eyes because they aren't properly adjusted. Not to bad out of the box, but still can be a lot better. As for the High beams? Wow these things are amazing, and give me a lot more output and range from my OEM's.
As soon as I get some extra time I will post up some pics. We got them to fit without clips, but we did secure them from the bottom. So they are locked tight and are not going anywhere. So finally glad to have this project done and out of the way. I tell you what though, physically the car looks so much different even with just the headlight change. Looks like a completely different car. Overall glad with the purchase, and like the look.
Old Feb 21, 2009 | 02:38 AM
808MAX-SPEC's Avatar
Glad you like them. So what's the problem with the halos? Not sure what you mean by properly adjusted.
Old Feb 21, 2009 | 12:16 PM
NismoSpeed's Avatar
The low beam bulbs, not the halos... They still need to be adjusted a little better.
Old Feb 21, 2009 | 01:49 PM
atlridin's Avatar
My 2cents on these lights.
I put the same ones on my 00 max and they make the car look so much better. Unless of course you can afford the HID upgrade. I just left the clips in and placed the headlights on top. Tightened the bolts on the top down and was a tight fit.
As far as output, they are ok. To make it better I put in the Sylvania Silverstar Ultras on the the lows, highs and fogs. This gave a clean white look (no yellow) and about 20% more light. Got all for 50% off at Advance. The beams do need to be adjusted, not the Halos, Halos provide no real increase in light, just aesthetic. I actually had to use the Plastix by McGuire to day cuz the plastic was looking fogged and little cracks were all over. They look pretty good again.
Old Feb 21, 2009 | 04:51 PM
yazz's Avatar
Anyone know the part numbers for the 02-03 clips?
Old Feb 22, 2009 | 04:22 PM
1800bucks's Avatar
Is the aftermarket lens inferior to the OEM lens? If so, can the OEM lens pulled off the factory housing and put in place of the aftermarket lens? Was thinking of these or similar lights for my '01, but can't see spending $300 on lights that will be crap in a year. I love the '02-'03 HID's, but ****, those things are expensive!
Old Feb 22, 2009 | 06:35 PM
showgun9's Avatar
The housing lens itself is not the the main problem with the aftermarket ebay projectors, although some people complain of poor seals that allow moisture inside, causing fogging. The problem is the poor light output of the projector lens. To my knowledge the ebay lens won't fit OEM housings, but the Depo ones will.
IMO the '02-'03 OEM HID's are the best in performance/aesthetics. Buy them used for around $200-$350 each (includes housing, bulbs, ballast) either here in the Classifieds forums or on Ebay. You may also find just the 02-03 housings for cheaper and can source the HID equipment separately.
Old Feb 22, 2009 | 07:19 PM
DoubleOmax's Avatar
02 clips
Old Feb 22, 2009 | 10:29 PM
NismoSpeed's Avatar
Originally Posted by DoubleOmax
02 clips
Well they are great for now.. Anyways I wish i would of known I needed those clips before hand. Oh well, they are great and are not moving at all. Thx guys for all the help. I appreciate it
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
