How the F*** did i screw up installing clear side marker lights lol
Old Feb 27, 2009 | 07:48 AM
rosader's Avatar
Last night I pulled my side marker lights with a screwdriver and cloth then installed some clears, now neither one will light up (yes i put the bulbs back into the new housing) I don't know if maybe they werent working in the first place? i guess i never payed attention. What could i have possibly done to cause them not to work? How would i troubleshoot the problem?
Old Feb 27, 2009 | 07:49 AM
Stormzusmc's Avatar
did you try to reseat the bulbs? shouldve looked before you put it back in..
Old Feb 27, 2009 | 07:56 AM
321VQ35MAX's Avatar
I would play with the wire. That is what I had to do. They got kinked somehow during the change over. Weird!
Old Feb 27, 2009 | 09:16 AM
2damax's Avatar
Ha I remember doing mine and i was rushed so i shook the bulb a little to much and i had to get a new one. Start with the easiest solution.
Old Feb 27, 2009 | 10:33 AM
mist max2000's Avatar
bad bulbs by chance?..IIRC if one goes out the other goes with it... not 100% though..
Old Feb 27, 2009 | 11:03 AM
rosader's Avatar
Maybe the jerk when i pried them out damaged the bulbs
Old Feb 27, 2009 | 04:26 PM
2damax's Avatar
Yeah thats what i was trying to say. FYI when I broke mine I broke the front right and back left so they don't both have to go out.
Old Feb 27, 2009 | 08:58 PM
rroderiques77's Avatar
Demodded and Forgotten
Buy a test light and see if you've got power going to them.
Old Feb 27, 2009 | 09:04 PM
Bjs470's Avatar
yea play with wires or try a new bulb
Old Feb 27, 2009 | 09:59 PM
nsnrider's Avatar
check the fuse...
Old Feb 28, 2009 | 08:00 AM
Ray Torres's Avatar
Good to know cause i have to do mine too.
Old Feb 28, 2009 | 09:32 AM
4DSCDriver's Avatar
Did you put the right bulb in there?
Old Feb 28, 2009 | 01:31 PM
scottygill's Avatar
Try taking the bulb out and twisting it 180 degrees. At least with my LED bulbs there is a positive and negative. I dont know if theres any risk to it, but i always change my corner bulbs with the lights on so i can quickly identify which way is the correct way.
Old Feb 28, 2009 | 03:48 PM
sublime258's Avatar
They could have possibly never worked in the first place. I know I didn't realize my back (red) sidemarker lights didn't work until I went to replace them with clear sidemarkers and colored bulbs. You probably just need to replace the bulbs...
Old Mar 1, 2009 | 04:01 AM
biggs1120's Avatar
try your old bulbs first b4 u buy new 1's
Old Mar 2, 2009 | 10:16 AM
Insane Maxima's Avatar
cant be the fuse if the rears are still working ... theyre on the same circuit. but if those went out too, its gonna be the fuse under the hood.
Old Mar 2, 2009 | 11:05 AM
Kaane's Avatar
check fuse first for sure.
vingodine
45
May 21, 2016 12:46 PM
rtirbany
Sep 8, 2015 11:46 AM
98nismomax
Aug 13, 2015 12:44 PM
papo99
Aug 9, 2015 07:32 AM
yat70458
Aug 3, 2015 01:16 PM
