Solder, crimp or caps?
Old Mar 18, 2009 | 12:03 PM
squiggy2469's Avatar
I need to wire in a new pigtail to my engine harness for the maf. Does it make any difference which method I use to connect the wires? I have heard somewhere that solder can impede the current a bit.
Old Mar 18, 2009 | 12:32 PM
DJD's Avatar
DJD
Just crimp on the proper size butt connectors, and then either seal it up with either electrical tape, or shrink wrap tubing to keep the elements out and you'll be fine.
Old Mar 18, 2009 | 01:36 PM
pmohr's Avatar
No more Maximas...
Solder and heatshrink.
Old Mar 18, 2009 | 01:46 PM
Deckdout2's Avatar
Play with my balls
+ Two Hundred Thirty Five Thousand and 98/100 Cents
Old Mar 18, 2009 | 01:48 PM
UGAd13's Avatar
Old Mar 18, 2009 | 02:20 PM
fflint_18's Avatar
Unless you really know how to solder, use crimp lugs and heat shrink.
It's one of the only ways to get a good weatherproof seal.
A bad solder job is way worse than using crimps.
Another good method for small wire gauges if you can find them is Scotchlocks.
They are like crimps where both wires go in one side and you push down a plastic button which makes the connection. They have a conductive caulk inside them that keeops them good in any weather. Phone and cable companies use them outside for all their connections and don't use any heatshrink or anyting else unless the connection is underground or constantly wet.
Good Luck.
Old Mar 18, 2009 | 02:40 PM
SurraTT's Avatar
HR Swap Pioneer
Old Mar 18, 2009 | 04:30 PM
jeff5347's Avatar
ive crimped and capped things before and thats ok for inside the car where you wont get the elements touching them, but i found most stuff done where the weather can get at it plus vibrations i have soley done soldering. much better connection thats less able to seperate
Old Mar 18, 2009 | 04:58 PM
unrealii's Avatar
+2
I've had good crimps fail on me
Old Mar 18, 2009 | 05:48 PM
fflint_18's Avatar
Good Luck.
Scotchlok
I repeat, don't solder unless you know how.
Old Mar 18, 2009 | 10:05 PM
rroderiques77's Avatar
Demodded and Forgotten
Superglue it.
Old Mar 18, 2009 | 10:06 PM
Stormzusmc's Avatar
what i did when i wired my halos and led lights
Old Mar 18, 2009 | 10:48 PM
nismology's Avatar
http://www.posi-lock.com/
You're welcome.
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Nov 15, 2020 11:52 AM
05RLS2
Apr 14, 2016 11:49 AM
captchaos
Mar 15, 2016 12:18 PM
