time for a spring refresh...
Old Apr 3, 2009 | 07:29 PM
jimmax00's Avatar
Its time for some maintenance, the car its not running the way it should be, I think. I have about 114k miles on the car, and I am the original owner.
I don't mean to ask this question again, but I cannot find much on the search (a lot of stuff that I find and click on is broken or brings me to an entirely different topic).
So, I am looking to do that overhaul maintenance (replace wires, spark plugs, etc) job. I am used to replacing rotor and cap, but not on this car. Do I need to replace the ignition coils? Fuel filter? Honestly, aside for brakes, oil & filter, air filter, and tires, just about everything is original (except for listed mods below). Oh the headlight lenses are completely shot, but I can shine them up, right? No need to replace them.
So if anyone could chime in with a list of stuff to consider, or point me to a topic that is not broken, and has all that info, that would be great.
Thanks,
JimL
'00 SE 5spd. Otto FSTB, Cattman rear anti sway bar, Illuminas, SS brake lines, drop in K&N.
Old Apr 4, 2009 | 07:35 AM
GoPack's Avatar
There is definitely more and more stuff out there available for your hazy lights. I've seen stuff at places like Advance Auto and Autozones. It is kinda like a wax kit. I haven't used it yet, but I will have to sooner or later.
Old Apr 4, 2009 | 10:04 AM
skidz88's Avatar
Look in the manual under 100k maintenance, it's an important one IMO and you've missed it. Do all of what it says.
Old Apr 4, 2009 | 10:07 AM
Brasso.
Old Apr 4, 2009 | 10:27 AM
jasonmax's Avatar
try Maguire's PlastiX
Old Apr 6, 2009 | 12:23 PM
jimmax00's Avatar
Umm, my owner's manual only goes to 60,000 miles. Yes, it says, just duplicate it, so the 30k mark becomes the 90k mark. The only thing it mentions, as a foot note, is replace the spark plugs at 105k miles. Which I plan to do. I don't see anything else special. There are lots of things to inspect. So, I could use that as a guide line. Anything else?
Thanks,
Jim
Old Apr 7, 2009 | 06:45 AM
str8max's Avatar
When I worked on my grandparents caddy I got this stuff from Advance Auto it was in a silver bag and came with some sandpaper, polish and sealer. Works great!
Old Apr 7, 2009 | 06:58 AM
rroderiques77's Avatar
Demodded and Forgotten
Plugs
Automatic of manual tranny fluid
Cabin air filter
LOF
Air cleaner element
Inspect cooling system and flush if required
Did I forget anything
Old Apr 7, 2009 | 07:37 AM
fflint_18's Avatar
I'd look at the front end and check for any torn boots on axles, balljoints, sway bar links, etc. My bet is that you'll need
Sway bar links for sure, maybe sway bar bushings.
Maybe balljoints.
As a maintenance item I coat my axle boots with silicone spray every oil change. IMHO it keep them from cracking.
Just my 2 cents
dank4us
34
Jun 10, 2024 03:45 AM
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
homeyclaus
Sep 3, 2015 06:15 PM
