question on 5.5 belt replacement
Old Apr 14, 2009 | 08:13 AM
nissandrvr98's Avatar
before you flame-i searched for the past 10 mins with virtually nothing even remotely related to the engine, belts etc sooooo...
How difficult is replacing the drive/accessory belts on the 3.5?
anyone have a linky on the org?
thanks!
Old Apr 14, 2009 | 09:17 AM
diverdown3's Avatar
thanks!
The power steering belt is the only difficult belt. Do an advanced search for power and steering and sort by relevency. There are about a dozen relevent threads. I just did it last weekend.
Old Apr 14, 2009 | 11:28 AM
thanks man!...that was perfect. looks like the PS is gonna be a biotch-howd it go for you?
Old Apr 14, 2009 | 01:53 PM
diverdown3's Avatar
No fun. Bolts were rusty. Oiled them a couple times over a few days preceeding the change. Also purchased the KD tools serpentine belt tool kit. Picked up 12mm gear wrench vortex socket and 12 mm crows foot. Came in handy.
Old Apr 14, 2009 | 02:46 PM
hmmm...might be worth just havin my mechanic bud do it-thanks for the info
Old Apr 14, 2009 | 03:19 PM
pmohr's Avatar
No more Maximas...
It's not that hard at all.
Old Apr 15, 2009 | 11:52 AM
ghostrider17's Avatar
I watched my local Nissan Svc. Dude chg. mine last spring - and he had trouble with it, even while it was up in the air on a hoist, AND with the proper tools.
I pd. $175 and was GLAD to not have tried it meself.
There's a special tool you need to grab the tensioning bolt to the p/s belt, and it gets easily rusted, and hard to remove. Mine was well stripped after he got done.
gr
Old Apr 15, 2009 | 12:06 PM
diverdown3's Avatar
Have you done it on a 5th gen?
Old Apr 15, 2009 | 12:10 PM
Puppetmaster's Avatar
Here's a good write up:
http://maxima.theowensfamily.com/udp.asp
It is for a UDP installation, but the idea is the same, so just follow the applicable steps, obviously.
Old Apr 15, 2009 | 12:27 PM
MidtownNJ's Avatar
its just a different pulley tensioner system then what i was used to. It wasnt easy but it wasnt entirely difficult. the toughest part is finding the right tension so the belt does squeek but is tight enough to not fall off and everything works properly.
Old Apr 15, 2009 | 12:41 PM
thx puppetmaster-i did find this with diverdown's help.
with the max as my DD and the rover in a few pieces i'll prolly have my guy do it
Thanks guys
pmohr's Avatar
No more Maximas...
Yes, and it's the same exact way on the 5.5 and 4th.
To be fair though, I consider the Maxima VQ belts on the easy scale because of my experience in the performance area.
You want hard, just try to change the belt on a Z with a Turbonetics kit on it...holy hell. Pretty much have to pull all of the IC piping off the front of the engine.
You want medium, change the belt on a Z with a Procharger setup. Have to work around the procharger bracket.
Old Apr 15, 2009 | 01:44 PM
diverdown3's Avatar
Wow. You have had your hands on some serious performance motors.
Old Apr 15, 2009 | 01:48 PM
pmohr's Avatar
No more Maximas...
Had my hands on, built, installed, driven...I've had my fair share of fun.
Old Apr 15, 2009 | 01:56 PM
diverdown3's Avatar
Now you're just braggin'
Serously though, you're a huge contributer to the .ORG. Thanks.
PH98I30
19
Jun 13, 2016 02:38 PM
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
JMag90
Aug 25, 2015 09:17 AM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
