house hold paint on my car
Old Apr 17, 2009 | 11:53 PM
Teufelhunden's Avatar
there seems to be a splash of house hold paint on my car.. does anyone know how i can remove this? if thats even possible?
Old Apr 18, 2009 | 12:08 AM
a33i30's Avatar
Try getting a blade and scrapping it off carefully(wet it too), paint thinner might mess up the paint or surface. I have some paint on the bottom black part of my bumper too, I'm going to try to scrap it off.
Old Apr 18, 2009 | 04:20 AM
daredevil514's Avatar
Use a NEW blade and lightly scrap it off, all you want to do is get under that layer of paint.
I've done this before, it wont damage the paint unless you press too hard. Don't use thiner as it might damage you finish.
Old Apr 18, 2009 | 05:08 AM
RLW001's Avatar
Try "Goof-Off", you can get it at most home centers.
Old Apr 18, 2009 | 06:35 AM
TheOnlyMax88's Avatar
theres this compound i use on my car to get like caked on tar off, its used on boats really good stuff you MUST wax the area that you scrubbed though after. Ill edit in the exact name when i got outside
Old Apr 18, 2009 | 07:38 AM
Scottwax's Avatar
That's Mr. Detail to you
Plastic razor blade, overspray clay or a polishing compound.
Old Apr 18, 2009 | 09:06 AM
99Silvermist SE's Avatar
Nail polish remover works. Google search it.
Old Apr 18, 2009 | 10:21 AM
Ahmad_1290's Avatar
Rubbing compound works too
Old Apr 18, 2009 | 02:19 PM
Blitzfist's Avatar
not even kidding try using rubbing alcohol. used it on my car and it worked out great. didnt damage the paint at all either.
Old Apr 18, 2009 | 06:20 PM
johnnyd2k2's Avatar
I agree IPA ( isopropyl alcohol) will work I used it to get sharpy of my wall and it took the paint off with it lol but its gonna take all the wax off your car so be sure to rewax after.
Old Apr 18, 2009 | 07:28 PM
DennisMik's Avatar
Yes, rubbing (isopropyl) alcohol takes off latex paint. The longer the latex has dried, the more you have to rub. Been using rubbing alcohol to clean up painting oops for years.
Old Apr 19, 2009 | 07:07 AM
hmmm yes alot of tips here.. thank you!! gonna go try ALL of them out to see if it helps... damn it how did it get there in the first place?
Old Apr 19, 2009 | 07:12 AM
nsnrider's Avatar
drove over fresh painted lines on the road?
I've seen that happen numerous of times. PITA to clean it of especially if its bright yellow paint on a dark color car. GL
Old May 1, 2009 | 10:24 PM
wsrivers's Avatar
"Goof-Off" is good for that. GL
Old May 2, 2009 | 01:54 PM
96blackmaxSE's Avatar
boost me.....
NOOOO! GOOF OFF WILL EAT YOUR CLEAR COAT!!! USE GOO GONE!
Old May 2, 2009 | 01:55 PM
boost me.....
I REPEAT.....DO NOT USE GOOF OFF ON YOUR PAINT!!!!
Old May 3, 2009 | 08:57 PM
tooreckless00's Avatar
Theres a solution called "Ardex" it might be tough to find in stores so search for it but it should take it right off. Absolutely will not damage car. It's a heavy duty strength rubbing solution
Old May 4, 2009 | 06:26 AM
nissandrvr98's Avatar
+1 on plastic razorblade-same for taking off badges/emblems
Old May 4, 2009 | 10:17 AM
Progress's Avatar
It's business time.
I've used ether (engine starter fluid) to get tree sap off my car after virtually nothing else worked.
Lakersallday24
Jun 16, 2019 01:35 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
acw
Aug 13, 2015 12:50 AM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
