START-UP ISSUES - MECHANIC THINKS FLYWHEEL. THOUGHTS?
Old May 24, 2009 | 11:54 AM
dutch078's Avatar
keep it metal
The past few weeks I've been having some start-up issues. In short, sometimes the engine will turn over, sometimes it won't. It's like a 50/50 shot. I checked all the things that I could think of. The starter and battery are brand new, and the switch for the clutch pedal is fine. It doesn't usually happen on a cold start; but more so if I'm starting up again after driving for a while, like gassing up or something like that. So baffled, I took it to my mechanic, and he said it's most likely the flywheel - the teeth are apparently worn in a few spots and if the starter catches those spots, no dice.
I should have thought of this earlier, but didn't think of it in my frustration - can you diagnose a bad flywheel without looking at it? Because I know damn well he didn't pull anything apart to inspect the clutch and flywheel.
I'm currently running a JWT flywheel. Did some searching, and didn't turn up much on bad flywheels, so I'm not sure if this is a common problem, or if there has been anyone else who has had this issue.
The past few days I've had no issues with start-up. Maybe just coincidence. Is there anything else I should rule out before tackling the flywheel?
Please chime in with any advice or info. Thanks in advance!
Old May 24, 2009 | 10:12 PM
pmohr's Avatar
No more Maximas...
By 'turn over' are you referring to cranking or starting? Generally it's regarded as starting.
You don't need to remove the flywheel to inspect the ring gear, it's plainly visible.
If you mean cranking, do you hear the starter try to spin when it won't crank (doesn't sound like it, given you mention the clutch switch)? If not, it's either the starter itself or electrical (relay going out when it warms up, etc).
Old May 26, 2009 | 05:59 PM
dutch078's Avatar
keep it metal
when it doesn't start, i don't here anything except for the fuel pump. it happened to me again yesterday. for about 20 minutes or so, nothing. then all of a sudden it decided to start up as if everything was fine. really bizarre.
Old May 26, 2009 | 06:01 PM
pmohr's Avatar
No more Maximas...
FIrst thing I'd check is the ignition switch, or it could be a faulty clutch switch. inhibit relay, etc.
Old Jun 2, 2009 | 01:08 PM
dutch078's Avatar
keep it metal
pm sent
Old Jun 2, 2009 | 07:46 PM
rlopez0095's Avatar
I HAD A PROB LIKE THIS ON A 4TH GEN MAX...AND IT TURNED OUT 2 B NOT ENOUGH GROUND UP AGAINST THE TRANS...
Old Jun 8, 2009 | 05:38 PM
dutch078's Avatar
keep it metal
can't hurt to rule anything out...thanks!
Old Jun 8, 2009 | 05:53 PM
Phantom-V's Avatar
Sometimes the flywheel isn't aligned up with the crank sensor. my car had bad starts...try that or the crank sensor. you have 2.
Old Jun 8, 2009 | 05:54 PM
pmohr's Avatar
No more Maximas...
He's only got one crank sensor, and two cam sensors. If the engine won't physically crank over, then the CKPS/CPS' are the least of his worries.
Old Jun 8, 2009 | 06:08 PM
Phantom-V's Avatar
your right, i got those two mixed. when i had problem mine cranked, but didn't start. you might have to Have a mechanic from Nissan to break it down...sorry about that bro...i know the feeling.
FlaMark
25
Aug 28, 2015 10:15 AM
FlaMark
Aug 21, 2015 11:06 AM
doctorpullit
Aug 20, 2015 05:15 PM
sc10692
Aug 9, 2015 09:37 AM
yat70458
Aug 3, 2015 01:16 PM
