Clutch Hose Removal
Old May 25, 2009 | 03:39 PM
Pri63's Avatar
Clutch Hose Removal
I need some help on removing the lower clutch hose. I'm not sure whether to use a pull or twisting motion for the removing the hose, I tried a to muscle it a little bit but got no where and didn't want to break anything.
I will try post a picture up for reference.
Pritesh
Old May 25, 2009 | 03:53 PM
Pri63's Avatar
Old May 25, 2009 | 05:27 PM
pmohr's Avatar
No more Maximas...
Are you trying to install an SS line?
That is one piece, it should go to a banjo bolt at one end, and a regular fitting at the other.
Where exactly is that picture being taken at? Can't really tell.
Old May 25, 2009 | 07:22 PM
Pri63's Avatar
Don't have SS lines yet but I'm having issues getting the lower stock clutch hose out.
Old May 26, 2009 | 06:51 PM
metalpiotr's Avatar
03 Maxima, 6spd
to remove it on that side, unscrew and pull out that bolt which holds the line attached to the clutch slave cylinder (the one right at the top of your picture).... I think that's the banjo bolt pmohr is talking about.
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
Socalstillen
Sep 20, 2015 11:46 PM
bumpypickle
Sep 20, 2015 08:22 AM
followthadollar
Sep 13, 2015 09:55 AM
